best bang for the buck?
Old Apr 6, 2005 | 11:25 AM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
anyone know who has the best bang for the buck brake kit?i dont wanna piece 1 together,my luck...id get a wrong part n never figure it out.......i dont wanna go with the baer system but i might have to.
Old Apr 6, 2005 | 11:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
get the C4 vette kit offered by Ebmiller88
his kit is just like the baer's but cheaper. 675 or so for the kit
and you get everything to bolt it on
comes with C4 calipers and 12 inch rotors.
modded spindles and brackets.
everything you need and it performs
i will be goin with with setup some time
also offers a Zr1/ c4 HD setup with bigger calipers and 13 inch rotors that are thicker as well. abit more money but still cheaper than any other company offers
Old Apr 6, 2005 | 02:36 PM
irocdan's Avatar
Car: 88 Iroc vert
im guessin thats his name on this site right
Old Apr 6, 2005 | 07:16 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
This all depends on what size wheels you run. 17"s or larger, C5s hands down. 13" C4 HDs will fit stock 16" Iroc and Z28 wheels, and the 12" C4s will fit inside 15" wheels.
Ed
Old Apr 7, 2005 | 10:58 AM
irocdan's Avatar
Car: 88 Iroc vert
any 14"(rotors) ?????? lolol just throwin it out there
Old Apr 7, 2005 | 03:21 PM
ebmiller88's Avatar
Yep...new C6 ZO6 brakes are 14". I'm still trying to get my hands on a used set but I may just go with new ones. These will probably force 18" wheels at least.
I've also looked into custom 14" rotors and then just piecing the rest of it together but honestly, it's not worth it. Too much brake for not enough car IMO. The difference in 13" and 14" performance won't justify the cost.
Ed
Old Apr 7, 2005 | 04:41 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
hey ed, sent you a pm last week and havent heard back, you mustve missed it
Old Apr 7, 2005 | 05:36 PM
ebmiller88's Avatar
Yep, missed it.. I replied to it now.
Ed
Old Apr 7, 2005 | 05:44 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
New C6 brakes or new C6 Z06? If you did mean Z06, might be hard to get a used set until they are actually released..
Kevin D.
Old Apr 7, 2005 | 06:12 PM
ebmiller88's Avatar
Sorry, I misspoke. The new C6s have 13.4" brakes, not 14". Still some big *** brakes. I just read the ZO6 write up in the May '05 GMHTP. Here's the brakes the ZO6 will have:
" 14" cross drilled front disc brakes with 6 piston calipers, 13.4" cross drilled rear rotors with 4 piston calipers."
Ed
Old Apr 7, 2005 | 11:40 PM
shr00m's Avatar
Did they mention the individual pads for each piston?? That's just nuts..
Kevin D.
Old Apr 11, 2005 | 02:52 PM
irocdan's Avatar
Car: 88 Iroc vert
ed,any word on my brakes? i sent a couple of pm's
Old Apr 11, 2005 | 07:58 PM
ebmiller88's Avatar
Sent PM Dan...I've been away for a few days.
Ed
Old Apr 12, 2005 | 08:00 PM
Igor's Avatar
Engine: 383 carbed sb
Transmission: th350
What about me? What can I fit for the front under my '88 16" GTA wheels. I want to keep the stock wheels and the stock "look", but mod everything else. I am using a 9" in the rear with lt1 brakes, but need a front solution. I would like something slotted or crossdrilled if possible.
Thanks.
Old Apr 12, 2005 | 08:09 PM
ebmiller88's Avatar
Biggest you can fit in a GTA wheel is a 12" LS1 setup, and you'll need a spacer under the wheel also. You can also run a 12" C4 setup, Mongoose runs those on his Formy.
Ed
Old Apr 12, 2005 | 08:22 PM
Igor's Avatar
Transmission: th350
Cool, thanks. E-mail me the prices on the two setups if you got them. igor455@shaw.ca
Old Apr 12, 2005 | 08:33 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
if your car had stock drums in the back, you can use the spacer from them on the front for ls1s with gta, thats why i hate getting rid of stuff, never gonna know whem im gonna need it
Old Apr 12, 2005 | 09:50 PM
Igor's Avatar
Transmission: th350
yup, i still got those spacers. I'd like to get matching front/rear rotors, so I would have to get rear lt1 rotors and front ls1 rotors. Are stock ls1 calipers good? Or should I look at aftermarket ls1 calipers? The idea is to make the car perform the best I can while keeping the stock look.
Thanks guys.
Old Apr 12, 2005 | 11:08 PM
ebmiller88's Avatar
A LS1 caliper is a LS1 caliper, "aftermarket" ones would simply be rebuilt. You can always get brand new ones if you feel you need to. I find that a used set is usually in great shape since they're not that old, then I just rebuild them to ensure they are up to snuff.
Ed
Old Apr 12, 2005 | 11:48 PM
Igor's Avatar
Transmission: th350
So do you offer an ls1 kit? if so, e-mail me the price and parts involved (minus rotors/pads). Thanks.
Old Apr 12, 2005 | 11:51 PM
ebmiller88's Avatar
Old Apr 13, 2005 | 01:33 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
Would the 13" c4 HD's fit under stock 16" formula rims(the 87 rims that bow out, not the concave 88-92 formula rims) ?
Old Apr 13, 2005 | 03:59 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I pieced my C4HD setup together for under $325. I got the rotors for the price of shipping, the calipers and pads for like $50 or something, and the rest of it from Ed for $260 or something, don't remember how much I spent on each individual item, but I know it was $340, but I sold some extra parts that someone included (rear pads with the calipers/front pads) for $25, so I was at $315, and then I just spent $6 the other day on the banjo bolts I needed.
Everything is used, the calipers should be good, I re-assembled them myself. I'll need to get new pads, but not bad for ~$325. I plan on installing the kit tomorrow to help fill up my 17" rims
Old Apr 14, 2005 | 03:38 AM
ebmiller88's Avatar
I think so but I didn't get to test fit that specific wheel, just the other Formy wheel.
Ed
Old Apr 15, 2005 | 10:49 PM
ebmiller88's Avatar
Check this thread, let me know if that's the right wheel type or not:
https://www.thirdgen.org/techbb2/sho...hreadid=237436
Ed
69GTOby
Apr 18, 2016 02:34 PM
BrianI
Oct 3, 2015 12:57 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
