Caliper fitting
Old Apr 9, 2005 | 08:54 PM
Charged89GTA's Avatar
Car: 89 Trans Am GTA
Engine: Paxton charged 355
Transmission: Th400 soon to be ZF 6-speed
Caliper fitting
I am looking for an answer to my headache.I have a 89 Trans Am GTA that the calipers froze up in since it has been sitting since 1998.I pulled the old units off and replaced them with OEM units.In placing the new units on there is a lot of slack (3/8 inch) from front to back on the rotor itself to the point where the front pad can allmost pop out.They are the same exact units as the ones pulled because I hit the piston back in with a hammer on the old unit,fitted it and had the same problem.Any suggestions?!
Old Apr 14, 2005 | 03:44 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Old Apr 14, 2005 | 02:35 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I think you have to have pictures to know what you are asking about.
Old Apr 14, 2005 | 02:38 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Old Apr 14, 2005 | 02:47 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Old Apr 14, 2005 | 10:01 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
After bleeding, press the brakes, and the problem should be solved if I'm thinking correctly about what you're saying.
New2Chevy
Sep 28, 2015 12:35 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
BOOT77
Sep 5, 2015 03:55 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Formula_88AE
Sep 3, 2015 01:47 PM
