4th Gen rear brake hard lines
Old Apr 17, 2005 | 12:42 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
I looked at the prebent brake hardlines places (Fine Lines, Classic Tube, and Inline Tube ) and none of them have the hardlines for 4th gen cars which sucks cuz i have a 4th gen rear.
ANyone know where they sell pre-bent rear brakelines for 4th gen rears?
Old Apr 17, 2005 | 03:07 AM
firestorm's Avatar
Car: Firebird
Engine: LG4
I'm in the same boat. Yards wont seperate them from the rears, so I guess you'll have to fab some up yourself. I'd like a prebent set.
Old Apr 17, 2005 | 09:17 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The guys at Fine Lines said the cars were still too new to warrant making the lines for sale yet but if I wanted to send them a set of stock lines they would make a set for me, maybe you guys should try the same thing.
Ed
Old Apr 17, 2005 | 10:08 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I took a gamble on mine and thought to myself "92 and 93 brakes are about the same, the tie in point is the same, they're pretty much all the same except for being 4" wider"..
I figured I could 'stretch' those extra 2" each side if I had to. So I ordered the 92 disc axle lines from In-line Tube. Got them in stainless and I love them. Don't ask me where the extra 4" comes from, because they pretty much bolted up with very slight re-bending..
Won't help people with the newer none-T rears, but worked for me!
Kevin D.
Old Apr 18, 2005 | 07:44 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Kevin D.
I did the same with my 99 rear end. Just had to pull the lines maybe 1" on either side.
Old Apr 18, 2005 | 11:10 AM
cali92RS's Avatar
Car: White KSwisses
Im probably gonna give that a whirl. The rear is about 2" longer so i can let out some bends on each side and that should work.
Old Apr 18, 2005 | 02:19 PM
ebmiller88's Avatar
In the above pic, you can see where the lines are bent...I'm sure you can pull enough line to make them work, you're only talking about 1.5" or so. If they're that close, there's no use in having another set made...just use the lines for our cars.
Ed
Old Apr 20, 2005 | 07:51 AM
ckjoshz28's Avatar
thats 1/4" line right? on forth gen rears...
Old Apr 20, 2005 | 11:29 AM
Red92TA's Avatar
Car: 92 TA, 91 RS, 98 Tahoe, 95 S10
Engine: 305 TPI, 350 Vortec TBI, 350 Vortec, 4.3 Z
Transmission: 4L60, T-5, 4L60E, T5
The best way to get the correct brake lines? You guys will not believe how cheap the original lines are at a GM dealer!!! I got them for $10 a side (though I get employee price). Retail should be $20 a side at most....and did I mention they fit? The only issue I ran into from there was to get the ends on the inside of the lines changed to mate up with the 3rd gen block that is on the "soft" line from the body.
Old Apr 22, 2005 | 10:19 PM
cali92RS's Avatar
Car: White KSwisses
You dont happen to have the part numbers for them do you?
Old Apr 23, 2005 | 08:23 AM
Red92TA's Avatar
Actually I do!! I am glad that I keep all my bills in a pile sometimes. I can't tell you what side each # is, but if you need both it doesn't matter! 10289430 & 10289429 Now after looking at my bill, I paid less than I thought. Each line cost me $5.00...and they list at $10.35 each!!!! To cheap not to buy them from GM!!!!!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
