headers touching brake lines
Old Apr 18, 2005 | 07:05 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
i just put my headers on, they are hedman shorties, the header on the drivers side touches a little bit of the brake line coming out of the MC, the brake lines have another piece of metal wrapped around them probably for heat dissapation but its like theres a spring around the lines kinda.. will this matter?
Old Apr 18, 2005 | 07:35 PM
91Z28-350's Avatar
bend them out of the way
Old Apr 18, 2005 | 08:30 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
What he said. You can bend them quite a bit, try not to kink them though. I had to really massage mine for my SLP 1 3/4" shorties.
Old Apr 18, 2005 | 10:30 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I have the same problem, only I have lame flowtech headers with no heat insulation. If you wait long enough, as I did, the brake fluid will get too hot and you have some funky braking. My stupid line keeps moving back closer to the header though everytime I bend it, not next time though.
Old Apr 21, 2005 | 10:57 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
defenitly bend them, as a metter of fact im glad i saw this because i need to check up on mine and make sure they didnt move!
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
