I can't get my brake piston back in!
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm doing the rebuild, I'm almost done but I can't thread it back on. The spring pushes on it too hard I guess. What do I do? I didn't remove the bolt on the back of the caliper that holds it on, I hope thats not necessary becuase its rusted on.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I have zero experience with the iron rear calipers, but would it be possible to use a large C-clamp to put pushing pressure on it and then screw it in with your hand? C-clamps work wonders to press pistons back into bores, but I've never heard of screwing a piston in (granted, like I said, I have no experience with the non-1LE setups).
Car: 86 T/A
Engine: HSR 355
Well I took it to a shop and the bolt snapped so I'm gonna just get new calipers I guess, hopefully with the Piston installed. That sucks so bad.
Car: 1997 Corvette
How hard is it to upgrade the rear brakes to get rid of the iron calipers? Go with the 1LE/LT1 setup if its not too expensive.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1997 Corvette
Good to know. Not that I'll ever own a car with those brakes, but that I at least know of another tool's existence
sailtexas186548
Jan 19, 2016 12:21 PM
