brake lines
Old May 29, 2005 | 11:59 PM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
brake lines
this weekend I was changing my fuel filter and my rusty old fuel line broke so I bought a 1' fuel line replacement peace but when I did that the brake line got moved a little when I was putting in my fuel line. my brake line that go's from front to rear got a big leak. now I need to know if I need the replace the hole front to rear line or patch it or is there a partial replacement thing like I used on my fuel line. Here’s a pic of where it broke. thanks for the help!
Old May 30, 2005 | 12:00 AM
Car: 1988 formula
its not very rust about 10" from where its broke heres a pic
Old May 30, 2005 | 06:26 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Wow...rust. Napa carries replacement pre flared lines that you can bend to the shape you need. For a custom line, call Fine Lines Inc. (www.finelinesinc.com) and you can get prebent lines what will install in a snap. With all that rust, replace all your lines.
Ed
Old May 30, 2005 | 11:10 AM
Car: 1988 formula
yea im planing on doing all my lines but not now im only 14 and i dont hardly drive the car so i just am looking for a quik fix but im going to replace fuel and brake lines before i turn 16
Old May 30, 2005 | 12:36 PM
ebmiller88's Avatar
Quick fix= Napa lines, but these are the brakes so take your time and make sure you do it right, not being able to stop would suck.
Ed
Old May 30, 2005 | 04:18 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Same thing happened to me.. I tried a few weeks ago to get it off and figured i'd let it soak a bit, did no good, that line is stuck together, and it started leaking, then stopped, etc. Yestarday I gave it one last crack but the brake fluid started squirting out at that point.. I just got mine in from fine lines and I got a stainless steel, but it took them almost THREE WEEKS to get it here.. I'm eventually going to replace my fuel lines with stainless also, but I just don't have an extra $300 lying around for that right now.
Before:
After:
Old May 30, 2005 | 08:22 PM
SLAYER6669's Avatar
Got the line in on both sides now..
Old Sep 4, 2005 | 11:03 AM
Rivi's Avatar
can one of you guys tell me is that line running back bubble flare or inverted flare? TY
Old Sep 4, 2005 | 01:44 PM
ebmiller88's Avatar
Should be a bubble.
Ed
Old Sep 5, 2005 | 04:10 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Eeeewww... RUST!!! Thank *** I live in the south!!
TIP - Go to a good electronics supply store and buy some 1/4" MARINE grade shrink tubing in a 25' roll. Slip this on the new lines, shrink it, and you'll have water-proof (rust-proof) lines that also are protected from debris impacts.
Old Sep 6, 2005 | 09:08 PM
ebmiller88's Avatar
Good tip!
Ed
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
