C5 Corvette caliper question
Old Sep 3, 2005 | 12:59 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I'm putting the c5 calipers on my front and using hawk brake pads. The pads did not come with the rattle clips. Do I need to use these? Where can I get just the clips if I need them? Thanks,Josh
Old Sep 4, 2005 | 06:11 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Yes, you must use the clips. They are for noise control but more importantly they guide the pads for even wear.
Old Sep 4, 2005 | 06:26 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
How do I get just clips???
Old Sep 4, 2005 | 09:02 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Good luck finding them, I ended up just buying a set of stock GM pad's from Dal on top of the Hawk's pad's in order to get the clips beacuse I didn't have time to search.. AFAIK there is no way to get the clips alone (from GM at least)
Old Sep 5, 2005 | 08:58 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Clips aren't available by themselves, you'll have to buy pads or happen upon a set to get them. If you don't mind used, I have a set, maybe two, on hand...yours for shipping cost but I'll need to check.
Ed
Old Sep 5, 2005 | 03:29 PM
BOTTLEDZ28's Avatar
Transmission: A4
I will take a set of those clips if you have a spare set.
Old Sep 5, 2005 | 03:31 PM
ebmiller88's Avatar
I'm out of town right now but will check when I get back.
Ed
Old Sep 5, 2005 | 08:14 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Call Carquest, they have them!
Old Sep 6, 2005 | 07:33 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Advanced auto has what they call a brake hardware kit. It had all the clips and dust boots for the pins. I think it was 15$ for both sides.
Old Sep 6, 2005 | 09:10 PM
ebmiller88's Avatar
Got the part number for that?
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
zayne0
Aug 24, 2015 07:22 PM
redmaroz
Aug 16, 2015 11:40 PM
