1le proportioning valve question
Old Jul 19, 2005 | 09:54 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
When ordering a new valve from gm does it come with the mounting bracket?
It looks like you can't remove the bracket on the ones I've seen.
Old Jul 19, 2005 | 10:04 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
yes it does
Old Jul 19, 2005 | 10:43 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Yes it does come with the bracket, i just ordered one last week.
Old Jul 19, 2005 | 10:47 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
just got mine yesterday from gmpartsdirect.....comes with one
Old Jul 19, 2005 | 11:03 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
thanks.
Old Aug 10, 2005 | 02:22 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Re: 1le proportioning valve question
ALmost ready to do a c4 upgrade from ED. He has mentioned on several posts to use the 1LE proportioning /combo valve. I have read the thread pitch changed mid year '89 which is what I have ?
So there would be two valves, one early '89 and down and one late '89 and up. I don't trust GM as far as production dates and what was installed that way, how would you know which one you had by looking ? Also any part numbers would be appreciated.
Thanks,
Bill E.
Old Aug 11, 2005 | 01:21 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I just got screwed by GM's mid year change on my 89 IROC, anyone need a late 89-92 prop valve? I am doing a C4-HD upgrade and I purchased the 1LE valve for late 89-92 and it's the wrong valve. The 82 - early 89 cars have a much finer pitch thread on the tube nuts then the late 89-92 cars. You can use a thread pitch gauge that come in most tap and die sets or you can buy them for a few bucks. The 82 - early 89 cars had a finer thread pitch of 1.0 and the late 89 - 92 cars had a more coarse thread pitch of 1.5.
Here are the part numbers:
14089496 1989 1st design: M1.0 tube nut threads (For 1982 - early 1989 applications)
10164112 1989 2nd design: M1.5 tube nut threads (Late 1989 - 1992)
Old Aug 11, 2005 | 09:21 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
89 Iroc Z: Check you pm's, I am interested in the valve.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
