Confirm my thoughts
Old Oct 18, 2005 | 01:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Confirm my thoughts
Confirm my thoughts
My fancy dandy brake pads were pretty worn out. Almost nothing left. So I traded them in for a new set but then I still didn't have muchif any brakes. They stop but you quckly hit a wall of pressure.
I assumed my fancy pads had worn the rotors to much.
So I just go my new rotors in the mail. $75 shipped.
When installing them I only had to push the calipers in a tad.
The new pads looked fine. And what do you know. I get the same results. Little bit of brake then I hit a pressure wall.
Both calipers were replaced in 02 limited life warranty with the rubber lines.
So about 99% sure its the calipers are now bad.
Had a bad line before and it would make the brakes lock shut.
So I am tossing that out as a problem.
Old Oct 19, 2005 | 09:55 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
What do you mean by hitting a pressure wall?
Old Oct 19, 2005 | 01:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thinking now that its my brake booster.
I went ahead and traded in my calipers.
{ I only get to do that once,so I wasn't in a rush.]
So new pads, rotors and calipers and its only a tad better. I flushed all the front fluid and bleed well. Used 1 gaint bottle and a half.
But I think now its the booster as I have brakes until I start to push hard and then it feels like I got manual brakes. Like pushing the brake pedal with the car off.
Though I should probably do the master cylinder while I'm at it.
But man that another $130 plus time servered. Maybe i can find a 100,000 or less brake booster used cheap. Mine lasted 220,000
tyeo098
Nov 30, 2015 06:27 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
buckeyecelt
Sep 24, 2015 05:50 AM
89 formula TPI
Sep 7, 2015 11:06 AM
IROCZ1989
Sep 4, 2015 11:54 AM
