93-97 Rotors on a 87 IROC
Old Jan 10, 2006 | 08:20 AM
link85x's Avatar
Car: 1988 IROC-Z
Axle/Gears: 10-Bolt w/3.08's (dying)
Couple of questions:
Will a pair of 93-97 rotors fit in place of my old rotors up front with not strings attached? I have swapped in a 4th gen rear, and i got a deal on some 93-97 4th gen rotors, front and back. Will my calipers work with the 4th gen rotors up front if they fit?
Old Jan 10, 2006 | 12:44 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
93-97 rotors are not a direct bolt on. 82-92 and 93-97 spindles are completely different. I'm having a brain fart on terminology, but basically our rotors have the wheel studs in them and are held on by the wheel bearing and nut. 93-97 are slip on rotors. Calipers are nearly the same I believe.
Old Jan 10, 2006 | 02:11 PM
link85x's Avatar
Car: 1988 IROC-Z
Thanks, that what i needed to know.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Derick15
Sep 17, 2016 05:28 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mustangman65_79
Aug 11, 2015 03:17 PM
