seized slider pin
Old Jan 30, 2006 | 12:33 PM
thunderoad02's Avatar
seized slider pin
I just replaced the rear brakes on my 97 Monte. The drivers side caliper is seized on the sliding pin on the carrier. Thus my pads are wearing prematurely on that side. I tried beating the hell out of it but it wont break loose. Anybody encounter a similar problem? Any suggestions?
Old Jan 30, 2006 | 12:39 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Re: seized slider pin
Heat. It does wonders.
Old Jan 30, 2006 | 01:29 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
Re: Re: seized slider pin
+1 I had to fight the fronts on the Formula. Out came the propane torch. It only took a few seconds with the burner to get it all loosened up. As always, make sure there's a functional fire extinguisher within reach.
K
Old Jan 30, 2006 | 05:06 PM
92MaroRS's Avatar
Re: Re: Re: seized slider pin
K
Penetrating oil would work aswell, but im not a fan of oil and brakes.
Old Jan 30, 2006 | 05:19 PM
I dont have access to a good heat source so I would have to take it to a shop and have them torch it. I thought about penetrating oil but I dont like using it around brakes either. I guess I could give it a shot by just unbolting the caliper and carrier and keeping the oil off the rotor and pads.
Old Jan 30, 2006 | 05:27 PM
KenV's Avatar
Car: A few
Engine: All Eights
In the absence of a torch, you could spray it with a little PB Blaster and tap it several times at each pin boss with a brass hammer. Bear in mind you'll want to follow up with brake cleaner. I didn't care since I was harvesting spindles for Ed Miller and preparing to install his LS1 brake kit in the same stroke.
K
Old Jan 30, 2006 | 10:10 PM
92MaroRS's Avatar
Swing by a parts store and grab a small 14 oz. propane torch kit, costs like $20 and will do the job.
Old Jan 31, 2006 | 08:47 PM
I didnt even think of buying one of those little torches. How the heck would I heat the pin though? Would I just heat the outside of the caliper around the pin? I guess i would have to buy no boot seals as they would be completely disintegrated. And what about the brake fluid, I dont imagine it would be too good to have fire that close to brake fluid
Old Jan 31, 2006 | 09:33 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
If you have any intention of NOT rebuilding the caliper keep heat away form the piston and especially the seal around it. Best bet is to soak it liberally with KNOCKER LOOSE or some variation for several days, then take the hammer to persuade it out. Brake parts cleaner will get rid of any of the knocker loose left over.
Old Jan 31, 2006 | 09:54 PM
92MaroRS's Avatar
Just use a pencil tip and keep the heat focused to the area's that the slide is stuck at.
As for fire near brake fluid, as long as you dont expose the fluid itself to the flame, you'll be fine.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
timonator
Sep 30, 2015 12:52 PM
