Will 13" C4 HD's fit behind Ronal R15's?
Old Feb 5, 2006 | 05:23 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
I've searched and found that some 13" brake kits will not fit Ronals. Does anyone have 13" C4HD brakes and Ronal R-15s or know someone that has them?
Old Feb 5, 2006 | 10:11 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
From my own car I have the Baer sport system that has 12in rotors and pbr calipers with r15s.. I can barely squeeze my index finger between the outside of the caliper and the rim, add the extra width of a 13in rotor and the caliper and I would say the fit is a no go.
Old Oct 15, 2006 | 09:24 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
they do fit, and I have proof! lol
Old Oct 24, 2006 | 08:08 PM
FASTERTHANUMARK's Avatar
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
And what proof do you have? Hehe
Old Oct 25, 2006 | 08:04 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
Originally Posted by ebmiller
13" C4 HDs fit stock 16" Iroc wheels and 16" stock Z28 alloys and larger wheels;
12.75" C5s fit most 17" and larger wheels, but will NOT fit Torque Thrust IIs without either grinding a bit off the caliper or fitting a small spacer behind the wheel (Contact Chevy Ken for more info);
12" LS1 front brakes fit 16" Iroc and Z28 wheels, and 16" Formula wheels; They'll clear 16" GTA crosslace wheels WITH a spacer between the wheel and hub other wise the caliper will hit the back of the spokes (See LS1 thread in FAQ);
12" C4s will fit most 15" wheels and larger, IE 15" 5 star alloys;
12" 1LEs will fit some 15" wheels and all larger sizes.
Ed
Old Oct 28, 2006 | 08:30 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Fitting 13inch rotors and PBRs will be seriously close with the Ronals if it fits at all, perhaps a bit of grinder work, even closer with some of the thicker calipers... Like I mentioned above my 12inch Baer setup barely lets me squeeze my index finger in between caliper and rim, there may be room I would love for someone actually running that setup to post a pic..
Now that is with PBR caliper.. If I had a choice again I would go for Ebmillers 4piston 13inch wilwood setup that would clear and cost less than my baers did...He just wasn't around when I bought them.
Old Oct 28, 2006 | 08:45 PM
Car: 1970 Nova
Engine: 850HP 383
Yes the C4HD do fit,no probs at all.
Old Oct 28, 2006 | 08:52 PM
Car: 1970 Nova
Engine: 850HP 383
Heres some proof.This is my complete setup that I did with some help of some friends.Dont mind the nasty caliper.I didnt want to scratch my Corvette embossed caliper.
Attached Thumbnails Will 13" C4 HD's fit behind Ronal R15's?-picture-009.jpg   Will 13" C4 HD's fit behind Ronal R15's?-picture-010.jpg   Will 13" C4 HD's fit behind Ronal R15's?-picture-011.jpg
Old Oct 29, 2006 | 07:27 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Cool, thanks for the pics!
I love the R15s but sometimes I wish they showed just a bit more brake!
Old Oct 29, 2006 | 08:48 PM
Car: 1970 Nova
Engine: 850HP 383
True,I like seeing brakes.
Old Oct 31, 2006 | 10:15 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
How much clearance is there between the caliper and the rim?
Old Oct 31, 2006 | 10:19 PM
Car: 1970 Nova
Engine: 850HP 383
Not much,LOL.Maybe a 1/4 inch.Id have to put in rim again.
Old Nov 1, 2006 | 12:16 AM
I haven't put mine on yet. I tried to mock it up but i had no way of holding the caliper to where it supposed to go and didnt have a spare spindle to use. Dont want thru go thru all the work pulling the 1LEs off to find out the 13's dont clear the Ronals. Is that the bracket from Ed? Maybe I'll get off my duff since it looks like it will fit, just got to move the stickie wheel weights out of the way. You figure more or less clearance with the Grand Sport calipers? Thats what I have.
Old Nov 1, 2006 | 09:05 AM
Car: 1970 Nova
Engine: 850HP 383
Crap I didnt even think of that b/c I have the Gran Sport calipers too.Guess Ill have to mock it again w/ the good calipers.I didnt do it the first time cause I didnt want anything to happen to them.
Old Nov 2, 2006 | 10:34 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Let us know how it goes, I am hoping it works out!
Old Nov 4, 2006 | 08:08 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
How much for the 6 speed stuff..lol
Old Feb 1, 2007 | 08:25 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
The 4 pot wilwood setup will clear the Ronals..??????
Old Feb 1, 2007 | 09:12 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I think they will.. if you can give me a bit of time I am putting a new Wilwood setup together soon and I may be able to check the fitup for you.
Thanks!
Ed
Old Feb 1, 2007 | 10:24 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Yes, the ed miller 13 willwood set up will clear the Ronals with the spacer provided by Ronal.
It also clears stock 91 16 in wheels with no spacer.
Ed, for the time I save you by this post get back to me on some brakes.
Old Feb 8, 2007 | 09:57 AM
Car: 89 formula 350
You've been waiting too, eh? My brakes are supposedly going to be done tomorrow, but im still trying to get ahold of him for some questions Ive had
Old Feb 27, 2007 | 02:37 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I can second that!
