Paging Dr. Miller and anyone else who might know
Old Feb 5, 2006 | 07:14 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Will Torque Thrust 2 wheels clear the C4 brakes? I was looking at using 17 x 8" up front with the factory backspacing and just want to know of any clearance issues with the spokes and the caliper.
Old Feb 5, 2006 | 07:56 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, both the 12" and 13" sizes.
Ed
Old Feb 11, 2006 | 02:30 PM
Mongoose's Avatar
Car: 90 Formula
How about the longer wheel studs? Would I need to use a lugnut other than a standard lug?
Old Feb 11, 2006 | 03:17 PM
ebmiller88's Avatar
The Dorman or ARP studs should work fine, even with the standard lugs. ARPs might be cutting it close.
Ed
Old Feb 11, 2006 | 05:48 PM
Mongoose's Avatar
Car: 90 Formula
Do you happen to recall which are in mine?
Old Feb 11, 2006 | 07:42 PM
ebmiller88's Avatar
Dorman.
Ed
Old Feb 11, 2006 | 11:38 PM
boussole's Avatar
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
rear
wath about rear upgrade to 1le i have 4 disk now i kno wat to do in front but cant find mutch on rear up grade
Old Feb 12, 2006 | 05:43 AM
ebmiller88's Avatar
I do those as well:
https://www.thirdgen.org/techbb2/sho...hreadid=345997
Ed
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Abubaca
Nov 5, 2016 12:22 PM
Fred SS
Oct 12, 2015 11:27 AM
Dragonsys
Sep 25, 2015 03:51 PM
