parking brake wont work
Old Mar 26, 2006 | 10:41 AM
skinwalker's Avatar
Car: 1989 IROC Z
Engine: TPI 350
Transmission: 700R-4
When I put the parking brake on, the car will not stop rolling. I have to put it in gear so it will stop rolling. What could be cause this to happen?
Old Mar 26, 2006 | 12:15 PM
MKnight's Avatar
A worn out ebrake cable would be the cause of this, or if it's fairly new it may be stretched and need re-adjustment.
Old Mar 26, 2006 | 01:49 PM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
e brake
Did you just change pads or shoes? If so you may need to adjust,if not like skinwalker said a worn out cable.
Old Oct 14, 2007 | 02:17 PM
csmethie's Avatar
Transmission: 5-speed for now
Re: parking brake wont work
what and why would you need to adjust after you change pads?
Old Oct 16, 2007 | 03:33 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
and if the rears are screw in (cant recall)u got to line the tab up on the pad with the caliper
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
