Brake Bleeder Kits
Old Apr 14, 2006 | 02:44 PM
86Trans Am 921's Avatar
Brake Bleeder Kits
Hi, does anyone know of some cheap one man brake bleeder kits out there? Also would I still need someone to push on the brake pedal when doing the bleeding? Hoping to find a bleeder kit where I don't have to have someone pushing on the brake pedal when I do the bleeding.
Old Apr 18, 2006 | 07:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just about any parts store has them - although not all are cheap. And - the cheap ones last maybe once, and are dead - they use elcheapo plastic parts.
Old Apr 24, 2006 | 04:54 PM
Mo's Avatar
Mo
there are one way bleader valves that i've used in the past that are pretty nice. i think earl's and russel make them. can definitely get through Summit, and probably parts store
Old Apr 25, 2006 | 12:52 PM
gbodybilly's Avatar
Car: 86 MCSS, 03 S10, 99 MX-5
Engine: 5.7, 2.2, 1.8
Transmission: 2004R, NV1500, Miata 5-spd
Axle/Gears: 3.73, 4.10, 4.30
Motive makes a pressurized one that fits over the reservoir (replacing the cap) and MityVac has the vacuum one that's done from the bleeder side. You can pick up the MityVac ones relatively cheap on eBay. Though they have several. The plastic ones are decent but not as durable (nor rebuildable) as their metal ones (Silverline line).
Old Apr 30, 2006 | 02:44 PM
Thanks guys, will check them out.
Old Apr 30, 2006 | 08:02 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
what are these kits?? why cant i just have someone sit in the car, pump 3 times hold loosten the bleeder screw, close it. pump hold loosen and so on and so forth? what am i doing wrong lol??
Old May 1, 2006 | 12:54 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You can. Nobody said you can't. This thread just brings up the idea that you don't have a second person you can still bleed your brakes.
I use a mityvac and combining sucking from up top and bleeding from down below it's a cinch.
Old May 1, 2006 | 05:42 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
ian, please explain this more. i have found that brake bleeding is never a "cinch". but i would like it to be. thanks
Old May 2, 2006 | 12:51 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Did you have a mityvac?
I've bled my clutch more than my brakes though. Just because the whole clutch system is hydraulic.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
LittleFranks
Sep 17, 2015 12:22 PM
lt1z350
Aug 28, 2015 05:57 AM
