1LE prop valve results.
Old Apr 25, 2006 | 09:25 PM
Eightyninef's Avatar
some history: 89 Formula WS6 came with iron front-J65 rears. Natually the brakes sucked; so I slapped on 1LE front brakes, and the brakes still sucked a$$. In fact braking was so poor, it was dangerous. I knew I had to be careful.
So I just got done installing my 1LE prop valve. All I can say is TOO MUCH rear BIAS ! The road is wet, and I'm locking up my rear brakes every where !!! like never before. I probably ruined my rear tires
The car stops much much better. However the only test drive was in the rain, and the rears are locking up way too easy..... I can't wait for some dry pavement, but the front still seem weak, or are not locking like the rears do.. although not as bad as before.... I can't imagine GM engineered it like this........ Has anyone gotten their 1LE brakes just right ?
Larry
Old Apr 26, 2006 | 01:38 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
My LS1 rears will lock before my front 1LEs will with the 1LE prop valve. Run a more aggressive front pad.
Old Apr 26, 2006 | 10:41 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
In the rain is a bad first test drive.....
Old Apr 26, 2006 | 02:54 PM
actually doing the first test drive in the rain was important. NOW I know to be careful in the wet. Otherwise I wouldn't have ever thought to wet test and dry test.
anyway, it's dry out today, and the brakes are working pretty good. The car stops much much better than before. However I havn't gotten them to lock up yet, either front or rear...... not that I panicked stopped yet. but I've been heating them up pretty good.
Old Apr 26, 2006 | 09:48 PM
TTOP350's Avatar
thats kind of what i ment.. get them broke in dry so you have a feel for the ol' gal then have at it
you could of had the fronts a lil bit wet/wetter and not as grabby as the rear. anyway glad they are working better 4 ya
Old Apr 27, 2006 | 11:59 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
You can see my brakes in the sig, 13" C4HD rotors in front and PBR 12"s in the rear. I also have a 1LE prop valve and I have never locked the rears. I know they are working well, but I have never locked them up. Once I get a little heat in the brakes these things become downright scary. My camaro will now stop as good or better than my Honda Shadow 1100. The front dives and this thing will stop so quick from high speed it is alarming. You have to be careful and not slam the pedal, I did it once and locked the fronts at 60mph. I have also waded into them pretty heavy from 100+mph and have never gotten them hot enough to even smell.
Enough bragging about my brakes, I have the same prop valve and rear brakes you guys do and can not lock the rears up. Could be because of the huge fronts I dont know.
Old May 1, 2006 | 09:10 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
where are you guys getting your 1LE prop valves? im in need badly or is there a chance i could run an lt1 or ls1 prop valve?
Old May 1, 2006 | 10:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've got two valves in the shop...
Hi Larry, long time no see. I've never had a problem with my Iroc and the 1LEs, wet or dry, even on the old tires that are still on the car from when I bought it in '96 or so. All I did was install the drum master and the new prop valve, bleed, align, and go.
Ed
Old May 2, 2006 | 08:54 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
how much you want for one of those bad boys?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
