brake lines
Old Apr 21, 2006 | 03:31 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
brake lines
Well when i replaced the master cylinder on my car and drove it the next day it was leaking brake fluid badly im guessing the new pressure of the master cylinder burst one of the brake lines. Is there any after market kits that replace every brake line for my firebird?
Old Apr 21, 2006 | 08:23 PM
JB22's Avatar
Fine Lines (finelinesinc.com) sells pre bent lines at a pretty reasonable price. I just got a set of rear lines in for my car, they look good. Will be installing this weekend.
Old Apr 21, 2006 | 10:50 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
brake kit
do they sell a brake kit that replaces every brake line for the entire car? if so what is the part number for a 91 firebird with rear drums?
Old Apr 22, 2006 | 05:28 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Fine Lines - Brake Lines , click the catalog.
I use them a lot.
Ed
Old Apr 22, 2006 | 05:49 AM
The Phantom's Avatar
There are many shops in the U.S. that sell pre-bent lines for both the brakes and the fuel. They are sold in the factory steel, or stainless. Just google it under "brake lines"
I was going to go that route, but with the exchange, brokerage fees and shipping to Canada it would have cost me about $300. It is quite reasonable if you are there in the U.S. and local. Most shops that I spoke with will require some lag time, as there lines are generally not an off the shelf item.
I ended up just buying a roll of tubing for each of the different lines (gas / brake) and bending them myself. This route was cheaper and I have to say fun! I removed the existing lines and just simply made the new ones to match the contours.
Old Apr 22, 2006 | 06:58 AM
JB22's Avatar
If you call up fine lines, tell them what you need and they will take care of you
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
