Spindle modified, Tap it or drill through it?
Old May 14, 2006 | 03:04 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
I want to see how many people when modifying their spindle have drill through it and just used a nut and bolt instead of tapping it. I want to see if their is any feedback on just using the nut and bolt, like the bolt coming loose or its not as strong, or anything. I am going to be doing my spindles next week and I have never tapped anything before and dont have the tools, but i guess i could go buy some, but it might be just as easy to drill through and use grade 8 bolt and nut.
Old May 14, 2006 | 04:38 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You will only be able to drill through the bottom hole, the upper mount is behind your strut bolt area so you can't do it there.
Ed
Old May 14, 2006 | 05:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd never tried drilling and tapping before my 1LE conversion. You'll need a drill bit and a tap. Not rocket science.
JamesC
Old May 15, 2006 | 02:23 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
Well duh, I didnt think about the top hole just the bottom bolt, thanks ed, i will just tap it and hopefully it will be straight
Old May 25, 2006 | 04:21 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
If it is not perfectly straight it will still work, mine has for over 2 years.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
91chevyz28
Feb 10, 2022 07:58 PM
InfernalVortex
Apr 20, 2021 11:31 AM
dimented24x7
Sep 6, 2015 03:51 PM
