IROC Wont Stop
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
IROC Wont Stop
I got new front pads had the rotors turned checked the rears and blead them all right rear left rear right front left front and blead the master. And she still wont lock up the Brakes. I tested the brake booster and it checked out ok . I have 15 to 16 inchs of vacume at idle. Anyone know what the problem could be she used to stop grate now the pedal is hard but spongy at the same time .
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I HATE TO BRAKE IT TO YA BUT................
You introduced air into the system.
Did you bench bleed the MC?
Also when doing all that bleeding it’s important
to never let the MC level get low enuff to expose
the bottom.
“If people drove any slower
they’d be going backwards.”
Engine: 364 Ci Ls2
I bench bleed the MC on the car there is no air in the system I dont have proper vac with this big cam at idle in drive I only have 12 inchs.
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Some pads, such as the Bendix Titanium line, have a special coating to decrease the bedding time.
BTW, it would help if you mentioned what you installed for pads. Some are good ( Such as Bendix Titanium, Stillen ) and some are crappola.
We did a survey on pads last year. Some good info there. Do a search for " What brake pads"
mustangman65_79
Aug 11, 2015 03:17 PM
