Brake line conversion Dbl flare to Iso?
Old Jul 3, 2006 | 08:41 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Hey,
I'm sorry if this has been asked before, but I'm unsure how to even search for this topic.
I have an '84 Firebird, which, to the best of my knowledge, uses double flares for the brake lines.
I just bought brakes off of a 98 Camaro (LS1 swap) and would like to use these brakes.
How exactly would I go from the double flare at the junction (rear axle) to the calipers? Is there some kind of adapter?
What about for the fronts??
Thanks!!!
Old Jul 3, 2006 | 10:20 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
there are adapters you can pick up at the parts stores, I thought 84 was the first year for iso ???
Old Jul 3, 2006 | 11:11 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
is it? Would make my life easier!!
Old Jul 4, 2006 | 09:21 AM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I replaced everything in the rear of my '85 Z28 and am in the process of replacing the front and I believe its all ISO bubble flare. Still not sure if and what adapters you may or may not need. The LS1 thread didn't cover this?
Old Jul 4, 2006 | 07:53 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
I just looked at the LS1 tech article, and that was vague about what years had double flares, and what had iso.. thanks though..
Old Jul 6, 2006 | 02:23 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I just replaced a wheel cylinder in my '85 and it had ISO bubble flares. But when I took one off my '84 junker, it had double flares. Howerver, the junker car was heavily modified before I got a hold of it (IE: 28 spline axles and no emergency brake hardware, even inside the drums), so thats still not really conclusive. From what I have seen between the two cars, there are alot of minor changes that took place between '84 and '85 like that.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
