Did I ruin my rear brake lines?
Old Jul 24, 2006 | 01:13 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
The springs on the ends of the LS1 brake lines that attach to the caliper are 1" longer than the ones on the 3rd gen brake lines. So I cut them to fit. (long story, no need to go through it because it doesn't apply to the problem.
Did I ruin the lines by cutting those springs shorter or will I be fine to use them?
Thx.
Old Jul 24, 2006 | 06:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unsure if you're discussing the brake lines (flex lines that attach to the cailper) or the e-brake cables, which have springs.
JamesC
Old Jul 24, 2006 | 12:49 PM
Car: 1994 Trans Am
E brake cables. Sorry.
Old Jul 24, 2006 | 02:43 PM
JamesC's Avatar
I assume that the length of the cables and their attaching points are still the same, so in that regard everything should bolt up. Being unfamiliar with LS1 brakes, I'm unsure of how cutting the springs will affect cable function (or if cutting them will affect anything at all).
JamesC
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
