difference betwn 1LE and c4 hd caliper? c4 hd caliper with 1LE rotor?
Old Jul 25, 2006 | 07:58 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I would like to eventually upgrade my front brakes. Because i have GTA wheels
I am limited to a 12 inch rotor. Now what is the difference between 1LE front calipers and c4HD front calipers? Could i put a C4 hd caliper on a 1LE 12 inch rotor?
Also are the 1LE calipers just normal c4 calipers? [is a plain jane front c4 calipers a 1Le]
sorry for soo many questions
Speed
Old Jul 25, 2006 | 11:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're similar, but I believe the width is different.
Old Jul 25, 2006 | 08:27 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Nope, width is the same and they'll pretty much interchange, the only difference is in the location of the banjo bolt hole...same casting. The standard C4 and HD calipers are indeed different and will not interchange. Standard can only take a .81" thick rotor, the HDs handle the 1.1" rotor.
Ed
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
doc
Sep 4, 2001 07:04 AM
Jason M 91Z
Oct 15, 2000 03:20 PM
