c5 rear brakes
Old Oct 29, 2006 | 01:52 AM
srhansen78's Avatar
Car: '92 Z28 25th anniversary/ '89 RS
Engine: 400 sbc
Axle/Gears: moser 12 bolt w/4.10
c5 rear brakes
i have done a lot of searching and i see a lot of info about c5 brakes on the front but i can not find any info about the back. can you install c5's on the rear?
Old Oct 30, 2006 | 11:11 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
C5 rear and LS1 rear are the same
Old Oct 31, 2006 | 03:51 PM
srhansen78's Avatar
Engine: 400 sbc
from what i have read the calipers are interchangable but it doesnt sound like the abutment is the same. i have also read that you have to use the smaller ls1 rotor with the c5 caliper. is this correct or have i read bad info?
Old Oct 31, 2006 | 04:33 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
srhansen78, i think you are thinking of mounting a C5 caliper in a 16 inch wheel. to do that youd need a C5 caliper and LS1 rotor. C5 and LS1 rear brakes are the same so just search for LS1. if youve got disc now its a pretty easy swap. drum is a lil harder but still not bad.
matt
Old Oct 31, 2006 | 08:14 PM
srhansen78's Avatar
Engine: 400 sbc
from what i have read it sounds as though the calipers are interchangable in the abutments, but the rotors are different. the size is a little different but the offset is where the problem is. is this true? does someone make a bracket for this offset so that you can use the c5 rotor and caliper? every one that i have read about is using the c5 in the front and the ls1 in the rear and if they are using the c5 in the rear, then they are using the ls1 rotor. This is where i am getting confused.
Old Nov 1, 2006 | 01:35 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
If it helps, i am running the LS1 brakes with the C5 calipers and pads. I had to use LS1 backing plates and abutment brackets but the calipers bolt up with no problems.........jt
Old Nov 1, 2006 | 06:15 PM
srhansen78's Avatar
Engine: 400 sbc
which rotors did you use?
Old Nov 1, 2006 | 06:42 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I'm using the Baer Eradispeed LS1 rear rotors.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
