no rear brakes
Old Nov 27, 2006 | 12:30 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
no rear brakes
ok im not a brake expert but i have no working rear brakes when i hit brakes car will slide forward like bein pushed i was told that was rear brake prob.. would i have to bleed them or any other way to get em to work?
Old Nov 27, 2006 | 08:13 PM
Engine: 355
how do i bleed rear brakes with only one person?
Old Nov 27, 2006 | 09:08 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Well I think the best way to do it is with a friend. Other than that I used a vacuum pump to pull the brake fluid and air out of the lines. I used a MityVac available at most auto part stores for ~$45.
Old Nov 27, 2006 | 10:01 PM
Engine: 355
Originally Posted by trumps2000
Well I think the best way to do it is with a friend, family member, or the hottest chick you can find. Other than that I used a vacuum pump to pull the brake fluid and air out of the lines. I used a MityVac available at most auto part stores for ~$45.
ok... umm whats the steps to doing rear brakes... i put new calipers in front and buddy said dont need to bleed rear.... is he right? i need to bleed rear cause not working...thanks
Old Nov 27, 2006 | 10:56 PM
trumps2000's Avatar
Car: 1985 Z28
Rear drum or disc? Should bleed same as the fronts.
Old Nov 27, 2006 | 10:57 PM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
Does your emergency brake work? Maybe your rear brake calipers are seized (IF you have rear disc brakes). Search the forums for "brake recall kit" for info about the recall on rear brakes. The brake recall kit comes with two new pistons and a few other parts that will fix the rear brakes. My rear brakes and my emergency brake did not work until I got the rear brake recall kit. GM Part # of the Kit is: 18019028 (you can get it at GMPartsDirect.com)
Old Nov 28, 2006 | 12:22 PM
Engine: 355
i have drum rear brakes i can spin the tirs by hand and gotta press brake all way down for it to stop them... maybe adjustment is needed?
also i disconnected my e brake along time ago no cable or anything undercar maybe that be stuck?
Last edited by billybob6110; Nov 28, 2006 at 12:23 PM. Reason: Automerged Doublepost
Old Nov 28, 2006 | 01:05 PM
trumps2000's Avatar
Car: 1985 Z28
Well I heard the rear disc was very hard to lock up, but I'm not sure about rear drums. Do you have a chilton manual? If not check out Autozone's repair pages, I think they're copies of the chilton manual.
Old Dec 2, 2006 | 11:12 PM
ALLTEC-Z's Avatar
Car: 1987 Trans Am
Engine: 5.7 T.P.I
Transmission: T-5 (Explosive under pressure)
There are adjusters between the two shoes behind each drum. Over time the shoes wear down and excessive brake pressure is required for the rears to engage. They self-adjust by making repeated hard stops in reverse. Then, repeated stops in forward and reverse. If that doesn't help, check your fluid level. If its ok, then bleed your system from the farest point from the master brake cylinder. Make sure you bleed your rears AND fronts; not just your rears. Good luck
Old Dec 4, 2006 | 01:12 PM
Engine: 355
i looked at em and only the front of the rer shoe on drivers side was working no other ones not even pass side... im replacing wheel cylinders cause the one blew the pin out in the side sooo yeah any suggest
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
