Brake sticking *Help*
Old Apr 21, 2007 | 06:07 PM
WaFFLesZ28's Avatar
Car: 1984 Camaro Z28, 1987 Z28 (R.I.P.)
Engine: 305 H.O.
Transmission: 5 Speed
Ok.. I have a 84 Z28, with 4 disk brakes. I was driving the other day and my car kept going on the left when I was braking, and I stopped and realise that my front (right) disk brake keeps sticking, since it was smoking hot. I just changed the caliper and brake pads, bleeded it and it still sticks, when the car is started it won't even turn. Does 84 Z28 have ABS brakes? (But why would it only stick on one side?) I didn't change the hose.. Could that be the problem?
Old Apr 21, 2007 | 06:19 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Re: Brake sticking *Help*
Likely your brake hose to that wheel is collapsed.
Old Apr 21, 2007 | 06:20 PM
WaFFLesZ28's Avatar
Engine: 305 H.O.
Thx.. I'll change it tommorow and see..
Nice IROC by the way!
Here's a pic of my car, it still needs some work.
Old Apr 22, 2007 | 03:04 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
What rims are those you have on your car? Also what size are your tire and the name brand of them. Car looks sweet like it sits.
Old Jul 3, 2007 | 08:43 PM
WaFFLesZ28's Avatar
Engine: 305 H.O.
Thanks for your help I did realise that it is the brake hose but I haven't changed it yet, I'm going to change the 2 in the front, Is the process just to take the old ones off, put the new ones, bleed the brakes and that's it?
IROCU2: My rims are just American Racing Torq-Trust.. 16 inchs and I think that there either 9.5 or 10 inches wide. The tires are Aurora 245/55
Old Jul 22, 2007 | 12:54 AM
Synful's Avatar
same thing happened in my dad's 65 mustang that he swapped to disc brakes
went through two sets of calipers, three master cylinders, bled them all up and down the place, and just about every thing else
turned out the brand new proportioning valve was bad. replaced that, no more sticking.
Old May 14, 2008 | 12:08 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
im having trouble with the same thing at the mo. i put on some braided brake hoses at the front, then replaced the calipers as i noticed the front right pads had worn down to nothing. but i checked them the other day and the same thing has happened. the brakes just arnt releasing. could i have twisted the lines when i installed them?
Old May 20, 2008 | 01:23 PM
karl's-92'-z28's Avatar
Car: Too many cars
May wanna check your propotioning valve.
Old Jun 10, 2008 | 12:37 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
so what happened??
Old Jun 19, 2008 | 01:10 AM
irocin rick's Avatar
Car: 1987 Camaro Z28 LG4 4bbl
Engine: 305 LG4
Transmission: Borg T-5
Axle/Gears: 3.73 open
had the same issues. On both sides when I bought mine. It was a chore getting it home lol. The rubber hoses are my bet. I checked/replaced every thing until I asked and some helpful guys told me to replace the hoses. It worked like a charm.
Old Jul 7, 2008 | 08:00 PM
roskoracing777's Avatar
You can also check that the sliding pins are sliding freely.
1992 Trans Am
May 10, 2023 07:19 PM
sonu1975
Aug 11, 2015 08:38 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
