brake help needed FAST
Old May 15, 2007 | 06:50 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Had a engine swap done. Car ran like crap but no problem with brakes. Had engine tune today and lifter set. Now no brakes. The guy who worked on car said lower vaccumm is causing this and is going to use larger fitting to get more vaccumm to brake booster. Is brake booster electric or does it work on vaccumm from block. Need answer fast. We blocked one side of PVC and seemed to help. Thank you in advance.
Old May 15, 2007 | 08:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: brake help needed FAST
Using a larger fitting isn't going to get "more" vacuum to the brake booster. If blocking the PCV improves things, then are you running the PCV and the brake booster to the same port on the carb? If so, don't.
Old May 15, 2007 | 09:35 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Either change ports to direct, constant non-ported vacuum or run a reservoir.
Ed
Old May 16, 2007 | 06:26 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
He blocked vent for more vaccumm. I guess it would suck air. The port that the line is attached too is very small. His idea is it is retricting the vaccumm. The brake booster is mateal except for the last 6 inches were it goes to small rubber hose, then to small port. What is constant non ported vaccumm?
Old May 16, 2007 | 12:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What kind of carb do you have?
Old May 16, 2007 | 06:46 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Ok, here the deal. When driving car, brakes are ok. At low speed or need to stop and go, seems brakes are weak. I think brake booster, mechanic said this is because put cam in. Had cam in and didnt do it, I think he is full of s#$t.
Old May 17, 2007 | 04:17 AM
ebmiller88's Avatar
There's two types of vacuum on carbs, ported and full:
From this site:
http://www.centuryperformance.com/timing.asp
"Ported vacuum means the port is drawing vacuum "above" the throttle blades in the carburetor. This means that as RPM increases, vacuum increases and in turn, vacuum advance increases...... With our suggestion of using the vacuum connection to full manifold vacuum, the port will be drawing vacuum below the throttle blades. A good running street engine will have a measured vacuum at idle between 14"-20" of manifold vacuum. Now, this will give you a ton of advance at idle, but as load increases (vacuum drops) you will take timing away. "
If you're tapped into ported vacuum, you only get good vacuum under load. You need full vacuum to the brakes, like off the manifold or just under the carb. What manifold do you have?
Ed
Old May 17, 2007 | 06:24 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
OK, the engine has just been rebuilt. The car brakes were fine. I took the car to have rockers adjusted. He adjusted rockers, set timing an set carb. When I pick it up it sounded great but brakes were hard. The mechanic said it was not getting vac because the engine was running right and the cam. Cam is .50 lift, nothing radicle. He installed a vac canister. I didnt buy it, how could tightening rocker decrease vaccumm, should increase. It has a edlebrook intake. The was a hose going to intake off fitting but it was very small, proably 1/8 inch. But, everything was working fine before he had it for 3 hours. I think he might have cinked something or pull vaccume line off somewhere or bgroke wire. seems strange to me. Also notice a little brake fluid on front of booster.
he said he could not figure out. holley 650, edlebrook
Old May 18, 2007 | 05:01 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Ok I will end this. I took car to my mechanic today, tired of the BS. Know I would spend cash, but it would be fixed finally. The fittings comming off the manifold were increased to 1/4 inch. The were about 1/8. Also rehooked the vents back in the valve covers. Installed a vaccum advance distributor to go along with carb. Also reran the lines going to the vac canister. Also hooked up the trans correctly. With the new accell distributor the car is brutal. Spins wheel effortlessly. Reminds me of a 71 camaro I had that I swaped out a 301 a put in a 400. That didnt have headers, hiflow cat, cam ect ect.
Fast355
Dec 2, 2016 06:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
