Brake cooling ducts
Old Jul 8, 2007 | 08:29 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Brake cooling ducts
Here's a couple of pictures of a brake cooling system I am installing on my 87. I didn't want to cut any new holes in the front bumper as I'm trying to keep things looking stock- I also didn't want to give up my turn signals.......so I combined them. i bought plastic cooling ducts from racer wholesale along with the hose. then I cut out the rubber from the back of the bumper where the stock turn signals went. I used a hole saw to completely remove the light socket from the original turn signal......then epoxied it to the side of the cooling duct......I will leave the bulb in the socket for driving on the street, then remove it and the lense for track days........I plan on using a screen of some sort to cover the duct when the lense isn't on it......The brakes are Baer 12 inch rotors which work great............
Attached Thumbnails Brake cooling ducts-backing-plate.jpg   Brake cooling ducts-cooling-duct-front.jpg
Old Jul 9, 2007 | 09:03 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: Brake cooling ducts
Pardon me for being blunt, but with the condition of that hose, it looks like that thing might just be waiting to kill you. This is one of those things I'd really question the need, but hey, your car. Whatever you like, it's there for you and no one else. :yes:
Old Jul 9, 2007 | 04:21 PM
hotrodln's Avatar
Engine: Lt1 in IROC
yeah the end of the hose is frayed, but it's actually a brand new hose. I plan on trimming it off before I do the final install. These cooling ducts are mainly for use on tracks.......when I go to Watkins glen, the car will easily get up to 130 on the straights......that's when you need cooling ducts.........not for trips to NAPA..........
Old Jul 18, 2007 | 09:42 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
I'm interested in doing this myself, but have been thinking about ways to conceal it more and how to direct the flow of air alittle better. You definately want the air flowing into the center of the rotor, but how are you hanging it in the wheel well? Is your hose heat resistant or have some sort of cooling properties to it? I've been checking into that and there are some companies that claim to have hoses that cool the air better than others' but i don't know for sure.
Why did you choose to route the openings behind the parking lights rather than say next to or behind the fog lights? They could still be plenty concealible there. Any other reason behind it? I figure why bother having to take the lights out if you don't have to.
Old Jul 19, 2007 | 07:38 AM
hotrodln's Avatar
Engine: Lt1 in IROC
The turn signal areas are perfect for getting through the bumper structures without major surgery to the steel of the bumper. If you take the nose off your car, you'll see what I mean. The turn signals are right in front of a nice rectangular opening in the steel bumper. The hose comes right through the middle of opening, hangs dwon slightly and will be tied to the sway bar at one point. This will allow it to move back and forth as the wheel turns. As far as the hose goes, it's from a racing catalog for this purpose. It doesn't contact the rotor anywhere, and it will have air flow through it most of the tiem, so i'm not worried about it melting. I'm more concerned about getting the hose routing right the first time, so the tires don't eat my hose.......This has been done before, so I know it can be done..........
Old Jul 19, 2007 | 10:45 PM
Car: 1986 Iroc-Z
Yeah I'm sure that it can and may happen. I still don't see why you wouldn't try and fit them else where though and still remain concealed. Why do something like this if it is only functional half or a quarter of the time. Anything can be done with alittle bit of creativity.
Old Jul 20, 2007 | 08:21 AM
hotrodln's Avatar
Engine: Lt1 in IROC
Well I don't know anyway of "concealing" the inlets except for where the signal lenses were....if you study the front bumper I think you'll see what i mean........i thought about this for about two years before I finally got out the saw.........I may leave the lense off all the time for continuous cooling, even though I won't need it........
Old Jun 1, 2009 | 11:03 AM
pg29's Avatar
Car: 88 GTA
brake ducts look good.
Old Jun 1, 2009 | 12:51 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Did you make the brake duct spindle hat? Or was it purchased from skulte or someone? I've been looking in to making my own once I get to that point in my build. I plan on using the air from underneath the car to push through the ducts by a small air dam
Old Jun 1, 2009 | 01:04 PM
Stephen's Avatar
Car: 87 GTA
If the air dam hanging under the radiator can direct enough air up & cool the engine, why not "rob" a little air from there & attach your ducts to it?
100% invisible, unless someone lays down under the nose & looks.
Old Jun 1, 2009 | 01:22 PM
hotrodln's Avatar
Engine: Lt1 in IROC
If i did this right, there should be a picture of the completed setup attached to this..........for the backing sheetmetal, I laid it out using cardboard and brought it to a local fabricator. it would have been allot of cutting and i wanted it to look neat.........the stub sticking out that the hose connects to started out as a rolled up piece of cardboard, then when flattened out was just a rectangle, so i cut that myself.......i thought about stealing air from the radiator, and i think that would work fine, but it's very close to the ground and i thought it would get squished once in a while. so far this has held up well. you have to have just the right amount of slack in the hose to round corners, but not so much that it dangles down and gets caught on things, or gets squished when you turn the wheels hard.....it took a while to construct this setup, but i could not find anyone to buy a similar one from.
Old Jun 1, 2009 | 01:25 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Are you running slotted/X drilled rotors to ?
Old Jun 1, 2009 | 01:31 PM
hotrodln's Avatar
Engine: Lt1 in IROC
yeah I am using Baer brakes up front, and NAPA rotors in the back. The Baer brakes make this car stop better than any car i've ever driven.....it's actually a good "safety" feature that i never would have thought of for regular driving........something runs in front of you, no problem.,.......mash the brakes and your stopped!
Old Jun 1, 2009 | 01:39 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
My stocks work good, to bad when i smash em the tires lock up, "not cool when u got new tires on and get flat spots "
How much where those Baer? Does it help at all to keep u from skidding like ABS?
I got my rotors from napa, there not xdrilled or slotted, and warped really bad, have any issues with that?
Old Jun 1, 2009 | 02:19 PM
hotrodln's Avatar
Engine: Lt1 in IROC
the baer brake setups for the front were about $1000. These things are gauranteed not to warp if you break them in right....lots of stops following their instructions.....i've leaned on these brakes something fierce, and never warped a rotor.....120 mph down to 60, then back up and down again ( at watkins glen, not on the street).....my lincoln mark 8 will warp any rotor you throw at it.....from cheapy chinese to expensive ones.....
Old Jun 1, 2009 | 06:01 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
that was my thought also.
skulte.com makes those plates, but he wants $200 for them. So i was going to do the same thing you are and have someone weld them up for me from a template. I'll be using ls1 brakes though instead of baer.
Old Jun 1, 2009 | 09:40 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
lookin' good!
Old Jun 10, 2009 | 07:16 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
what did that paint job run you..$$ The VW beetles old one have metal cooling ducts for the engine. same size as yours, plastic just seems short livedd
Old Jun 10, 2009 | 09:53 PM
hotrodln's Avatar
Engine: Lt1 in IROC
I did the paint work myself.......i probably spent $800 to 1000 on paint products.....there was also a bunch of hours getting the body straight and then polishing the paint when done..........
Old Jun 10, 2009 | 10:07 PM
amazing
Old Jun 10, 2009 | 11:49 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
I think that is a Great mod. And i love the way the mesh looks.
I would do the same, but i have a firebird
Old Jun 11, 2009 | 08:13 AM
hotrodln's Avatar
Engine: Lt1 in IROC
beleive it or not, but the mesh is from the hardware store...it's for a screen door.......i painted it silver so it would not rust.....the turn signal sockets were cut out of the original turnsignals using a hole saw, then epoxied into the plastic cooling ducts. Seems very simple now.....BUT it took a while of staring at it all to figure out how to do it....
Old Jul 22, 2022 | 08:28 PM
Tombowman89's Avatar
Car: 88 Iroc
Engine: 388 Vortec Pro-Flo 4 Small Block
Axle/Gears: 3.77 to 1
Alright purest… get over it, function. Some people believe cool brakes are happy brakes, so when you actually go fast it all counts like stopping on a dime and getting two nickels change!
Old Jul 22, 2022 | 08:32 PM
Car: 88 Iroc
I was going to try maybe turning the light housing into the same duct. I very much so like your idea at the rotor, how was the clearance?
Old Jul 22, 2022 | 09:26 PM
hotrodln's Avatar
Engine: Lt1 in IROC
I guess everything cleared fine. I've had no issues...BTW this thread is like 13 years old! I still have the car though.
Old Jul 26, 2022 | 11:26 AM
Car: 88 Iroc
This is roughly how it will look, my plan is to install with aluminum blind rivets.
Old Jul 26, 2022 | 11:30 AM
Car: 88 Iroc
https://starbuckinnovativedesigns.com
these guys have a very nice ducting kit and a very slick DOT approved functional turn signal/ inlet duct too.
Just depends on what you want to do with the car.
neigh-sayers and purest “ keep your thoughts and opinions to yourself”
Old Jul 27, 2022 | 02:54 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Starbuck does have some cool pieces for Camaro's but nothing for the Firebirds
I'm afraid it doesn't work that way on a public forum
Old Jul 27, 2022 | 03:54 PM
hotrodln's Avatar
Engine: Lt1 in IROC
Hey Tha'ts neat. when i did mine a million years ago i didn't see that.....I also had to add a spring to my drivers side hose to keep it pulled away from the tire.....the right side didn't need it for some reason.....do they sell the backing plate to hook the hose to?
Old Jul 27, 2022 | 04:25 PM
Car: 88 Iroc
this is what the kit looks like, I’m not sure if this answers your question about a backing plate. Unless your talking about a duct that goes to the brake rotor heat/dust shield, no one makes that for these cars unfortunately but it can be made I’m sure. The Starbucks stuff claims to fit with no concerns on tire sizes. Yeah kinda a bummer that parts aren’t made for the firebird, but I’m sure you could use some COTS part like a duct I purchased or some variation of a NACA duct to achieve your goals with little modifications. Good luck to all of you striving to achieve a superior third gen!!
Old Jul 27, 2022 | 05:32 PM
91banditt2's Avatar
Engine: 5.7 HSR
The brake ducts I’m putting together for my 91 Firebird, a work in progress. Do t mind the cardboard, masking tape and wire ties I don’t have current picture of the brake duct at the rotor/spindle, can’t Tig weld to save my life and waiting on my buddy at work to find time to weld them altogether.
Old Jul 27, 2022 | 09:07 PM
Car: 88 Iroc
I’m digging that, I seen something like that in a LS1 tech forum. Your doing nice work, man if you were close by I’d do your tig welding.
I guess that brake shield duct you designed and tacked together?
Hopefully the aluminum holds up to the heat, maybe a good heat treatment or something will help that thing live forever. But it’s very cool ”literally”
Old Jul 27, 2022 | 09:13 PM
Car: 88 Iroc
I’m also glad people are doing some posting on these forums again. Things were pretty stagnant for a while.
Old Jul 28, 2022 | 06:46 PM
Car: 88 Iroc
These are the two possibilities for installation in place of the front turn signals
Old Jul 28, 2022 | 07:50 PM
91banditt2's Avatar
Engine: 5.7 HSR
Mounting to the outside would be easier to mount, could use 4-6 1/4 black pop rivets, could reduce the OD of the ducts to make it them have less of foot print, you’d probably would want to use smaller rivets just more of them. Personally I’d go through the hassle of mounting them to the inside, just looks cleaner. What ducts are you using they look like the same ones I’m using.
Old Jul 28, 2022 | 08:23 PM
Car: 88 Iroc
I bought mine from eBay, but they look the same. It’s up in the air on what to do exactly. But internal mounting would benefit slightly on the aero aspect
But I agree internal mounting looks way better. I still need to trim it more if I go that route. Thanks for the technical advice, it’s appreciated.
Old Jul 29, 2022 | 11:36 AM
Car: 88 Iroc
I
I used patio screen for the debris prevention and also to cover imperfections of the cheaply made duct
Old Jul 29, 2022 | 12:02 PM
91banditt2's Avatar
Engine: 5.7 HSR
I
Did you paint them black or is that the color they come in? Looks good.
Old Jul 29, 2022 | 12:32 PM
Car: 88 Iroc
Yeah the ducts came in black, minus the FOD screen. Appreciate that
Old Jul 29, 2022 | 03:35 PM
Car: 88 Iroc
Starbucks innovation cooling duct roughed in
Old Jul 29, 2022 | 04:04 PM
91banditt2's Avatar
Engine: 5.7 HSR
Are you taking them through the fender lining or leaving them off?
Old Jul 29, 2022 | 05:32 PM
  #42
Car: 88 Iroc
They are going to be routed under the fender well as depicted in the image. It’s a very straight shot to the rotor brake system. I’m pretty satisfied with the time that Starbucks took into making this kit.
Old Jul 29, 2022 | 05:33 PM
  #43
Car: 88 Iroc
I just wasn’t willing to fork up 370 bucks plus tax and shipping for there inlet duct/turn signal housing.
my car isn’t going to be intended for street usage.
Old Jul 29, 2022 | 05:36 PM
  #44
Car: 88 Iroc
I’ll post more pictures of the process.
Old Jul 29, 2022 | 09:37 PM
  #45
91banditt2's Avatar
Engine: 5.7 HSR
Some progress tonight
Old Jul 29, 2022 | 10:09 PM
  #46
91banditt2's Avatar
Engine: 5.7 HSR
Playing with possible 3” hose routing, considering on taking them through the fender lining into the wheel well, don’t mind the photo bomber.
  #47
Car: 88 Iroc
Man I really like those ducks that you made out of aluminum. Would you build another set and sell some to me
Old Jul 29, 2022 | 10:39 PM
  #48
Car: 88 Iroc
When you get tires on let’s see some stop to stop clearances on the ground please.
Old Jul 29, 2022 | 11:48 PM
  #49
91banditt2's Avatar
Engine: 5.7 HSR
At full lock and at full droopthere doesn’t seem to be a lot of room for 3” hose 🤔
Old Jul 30, 2022 | 12:35 PM
  #50
Car: 88 Iroc
