whats the biggest
Old Jul 16, 2007 | 12:40 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
whats the biggest
brakes i can fit under stock iroc wheels. the project im doing im wanting to retain most of the factory exterior appeance, but stuff the most under that that i can possibly do. wheels are 16"
what options do i have?
Old Jul 16, 2007 | 04:19 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: whats the biggest
http://www.byunspeed.com/product_inf...171485711c5cd4
There's a 13" kit that spohn makes. I don't think you'll get much bigger than that.
Old Jul 16, 2007 | 04:57 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
will the c5 kit fit? probably alittle cheaper
i was thinking about the c5 fronts and ls1 rears
Old Jul 16, 2007 | 05:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
edmiller would be the one to ask this, but i do believe that he c5's require a 17" wheel , unless yoiu grind the calipers down a bit
Old Jul 16, 2007 | 06:48 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
he doesnt answer his pms... lol i went that route first
Old Jul 16, 2007 | 07:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well, he is a very busy guy...
Old Jul 16, 2007 | 08:49 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
yeah i don't think that the c5s will work under the stock iroc rim. I've always heard and read it requires 17in or bigger. Go ls1 or 1le front and rear and you will be good to stop on a dime
Old Jul 16, 2007 | 09:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Sorry fellas..I have 123 PMs in my inbox, I try to answer them according to date.
True C5s won't fit 16" Irocs, LS1s with C5 calipers will fit 16" wheels. The C4 HDs will fit 16"s, no problem. I also offer 3 Wilwood kits that will fit your wheels: (1) 12.2" setup and (2) 13" setups, one and two piece rotors.
Randy, PMs sent.
Ed
Terrell351
Jun 13, 2021 01:13 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
customblackbird
Oct 1, 2015 04:30 PM
dbrochard
Sep 25, 2015 04:56 PM
L0tuS
Sep 4, 2015 11:16 PM
