E-brake Broken????
Old Aug 22, 2007 | 11:18 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
E-brake Broken????
Alright, so last night I parked my car in my driveway and put the e-brake on. Since my driveway is so steep, I need either my e-brake or i have to jump out and put a block under my tire quick.
When I pulled the e-brake there was resistance (like normal) then it just went away. I heard a little bit of a snap, but i'm not sure if it was the cable that broke. Any one know where these e-brake systems are the weakest?? I'd like to get some input and know a little more about them before I just start tearing the car apart. Any help and knowledge that you guys can offer would be great. Also do i have to start junk yard hunting or is there somewhere where I can buy a new e-brake???
Thanks,
Kyle
Old Aug 22, 2007 | 11:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: E-brake Broken????
Most likely the cable has broken. Check the mounting point toward the front of the tunnel above the drive shaft. New cables should be had through any parts store.
JamesC
Old Aug 22, 2007 | 12:41 PM
86irocu's Avatar
Car: 1986 Iroc-Z
i need a new handle as well... its been broken for a while.. ever since i bought the car infact. So i could get the cable at autozone or carquest??
Old Aug 22, 2007 | 03:35 PM
JamesC's Avatar
JY for the handle. So be a dime a dozen. The cable can be had from any parts store, I'd think.
JamesC
Old Aug 23, 2007 | 01:10 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Is there a difference in handles from a disc setup and a drum setup??
Old Aug 23, 2007 | 05:34 AM
JamesC's Avatar
There would be no reason for them to be different that I can think of.
JamesC
Old Aug 23, 2007 | 09:49 AM
86irocu's Avatar
Car: 1986 Iroc-Z
I ask b/c if you look at ecklerscamaro.com they have them for disc and drum...
Old Aug 23, 2007 | 10:28 AM
JamesC's Avatar
This is what I found:
http://www.ecklerscamaro.com/product...dept%5Fid=1080
Note the "All" except 1LE--which is odd because I have an 85 and when I went to 1LE brakes on all four corners, I kept the same handle and all functions as should be.
JamesC
Old Aug 30, 2007 | 11:27 AM
86irocu's Avatar
Car: 1986 Iroc-Z
I fixed it. Turns out that the passenger side cable came out of the splitter underneath the car. Took me a little bit to get it back in there. Kinda hard with the 3" exhaust and the driveshaft in the way. I was kinda short on time, so I didnt have any time to remove those.
Old Aug 30, 2007 | 11:30 AM
JamesC's Avatar
Bet that was PITA.
JamesC
Old Aug 30, 2007 | 12:13 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Yes it was.... In a major way. I would like to tighten up the tensioner... but once again.. taking the exhaust apart and the torque arm and driveshaft off in a big PITA. Especially when your exhaust guy makes you exhaust fit as tight as he can get it so it doesnt leak... I tried pulling that intermediate pipe off... and it fits so tight that its almost impossible.
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
