Hard brakes
Old Sep 17, 2007 | 07:22 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
Hard brakes
just finished a swap to a 350 with a decent cam in it. my problem with my brakes is when stopped at a light or backing out of the driveway (at very low speed/no throttle) my brakes act as if they are not power brakes. is this due to low vacuum at idle speed? can I adjust/correct this or just live with it? stock brakes, stock master cylinder ect. thanks
Old Sep 19, 2007 | 10:33 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
Re: Hard brakes
anyone had this problem or know a solution?
Old Sep 20, 2007 | 04:19 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Hard brakes
get a vacuum canister.. you are correct about the vacuum.. a canister should cure your problems..
get em at summitracing.com
Old Sep 22, 2007 | 06:38 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Re: Hard brakes
And get one soon before you get into stop and go traffic and hit the back of someone because of a super hard pedal.
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
