Caliper Upgrade
Old Jan 16, 2008 | 04:27 AM
Stu's Firebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 305 5.0L V8
Transmission: Stock
Caliper Upgrade
I found these calipers on summit racing and I was wondering if these would fit a 1992 firebird 305 V8,5.0
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 16, 2008 | 05:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Caliper Upgrade
The site claims it will.
JamesC
Old Jan 18, 2008 | 12:29 AM
Engine: 305 5.0L V8
Transmission: Stock
Re: Caliper Upgrade
Do you think if they just bolt into stock boltings or would you have to change the mounting braket also to make them fit?
Old Jan 18, 2008 | 06:08 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Caliper Upgrade
Wilwood makes a caliper that im almost positive it will fit the front its there metric caliper.
Old Jan 18, 2008 | 11:11 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: Caliper Upgrade
would that be a replacement for the 1le styled calipers, the dual piston or would that actually work on a standard styled 10.5 or 1.75 whatever our size rotors are.
realy i mean for an extra 15 bux if it fits then what the hell it can't hurt.
the factory gm style caliper doesn't slide for **** how it's designed + the extra piston should give it a more even load i'd expect......
anyways any1 else have opinion on this?
Old Jan 18, 2008 | 11:15 AM
Guest
Guest
Posts: n/a
Re: Caliper Upgrade
Image is a representation of this part. Actual part may vary.
Old Jan 18, 2008 | 11:28 AM
JamesC's Avatar
Re: Caliper Upgrade
What mad said. Check the application and its for 82-92 fronts, which can only mean 10.5 rotors and single piston calipers.
JamesC
Old Jan 18, 2008 | 12:00 PM
SteelTownMadDog's Avatar
Re: Caliper Upgrade
What's so special about them? If you think you're getting a dual-piston because of the picture, read the fine print at the bottom of bigger version of that picture. You're probably getting a standard 1 piston caliper.
Old Jan 18, 2008 | 12:26 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Re: Caliper Upgrade
wow lol i'm special my bad definetly didn't look over it good enough haha o well it was a nice thought for the price..... o well.
Linson
Oct 24, 2025 02:00 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
the_hamturdler
Sep 30, 2015 12:50 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
