Is it a big deal ...
Old Jan 24, 2008 | 04:17 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
... to change rear discs from iron to PBR's?
Old Jan 24, 2008 | 05:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Is it a big deal ...
I assume you mean calipers. The swap is straightforward:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Providing the year and make of the car in question is always helpful. For example, if you have a 92 TA with rear discs, you already have PBR's.
JamesC
Old Jan 25, 2008 | 03:51 AM
watajob's Avatar
Car: 92 T/A 'vert
No. I found a pretty good deal on a nicely freshened up 10 bolt, (Torsen posi, moser 28 spline axles, T/A girdle, yada, yada, yada), but it's got iron calipers. Sounds like a pretty straightforward swap. Thanks!
gta892000
Aug 11, 2019 11:16 AM
david068513
Sep 18, 2015 10:36 AM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
