Brake kits the same?
Old Feb 4, 2008 | 04:20 PM
Phoenix1987's Avatar
Car: 1987 Trans Am
Axle/Gears: 4.10's
I am looking for a brake line kit for my 1987 Trans Am. I swapped to rear disk brakes (Iron caliper) and I am looking for a kit that has five lines. Both fronts, both rears and the rear flex hose T. I found a Russel kit for a 1989-92 that has all five lines. Will a 89-92 brake line kit work with the 87 iron rear calipers? If not, deos anyone know of a part number for a five line brake kit for and 87 with rear disk brakes?
Old Feb 4, 2008 | 04:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Brake kits the same?
The 89+ kit won't work with the earlier brakes. You want a kit that has 4 lines, not 5. Try Earl's 28A520ERL.
Old Feb 4, 2008 | 04:40 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
So get the 4 line kit and just buy a replacemnet rear flex line?
Old Feb 4, 2008 | 04:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, your car only has 4 flex lines.
Old Feb 4, 2008 | 04:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Chose the correct lines from the following (as mentioned, you need four flex lines. One of the rear lines is a hard line):
http://www.spohn.net/?action=shop&pcid=1082
JamesC
Old Feb 4, 2008 | 04:56 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
Sorry, I mean the rubber line that t
"Ts" off into the two rear brake lines.
This is what I was talking about. I new one.
http://store.summitracing.com/partde...5&autoview=sku
I thought I saw a brake line kit that included this
Last edited by Phoenix1987; Feb 4, 2008 at 05:01 PM. Reason: Automerged Doublepost
Old Feb 4, 2008 | 05:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, your car only has 4 soft lines total. One on each of the front wheels, one from the axle to the body, and one on the left rear.
Old Feb 4, 2008 | 05:48 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
Sorry for all ther confusion. I can build an Ls1 but am new to this disk brake swap stuff. LOL Would you happen to a picture of the rear set up?
The way I was told was get the soft line that bolts to the axle. The soft line "Ts" off into two hard bent lines that i will have to bend myself. From the hard lines into soft line to the calipers.
what am I missing?
Old Feb 4, 2008 | 05:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's no soft line on the right rear, the hard line connects directly to the caliper.
Old Feb 4, 2008 | 06:06 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
Is that for pressure purposes?
Old Feb 4, 2008 | 06:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
More likely for cost savings than anything.
Old Feb 4, 2008 | 07:12 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
So since I want to replace my front lines anyway, should I buy the earl's kit (front and rear lines) and build my rear brake set up off of that?
Old Feb 4, 2008 | 07:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you replacing the hard lines too, or just the soft ones?
Old Feb 4, 2008 | 07:25 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
I have to make new hard lines as well. All new in back.
Old Feb 4, 2008 | 07:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The Earl's kit will have the soft lines. You can buy pre-flared hard lines at your local parts store and bend them yourself.
Old Feb 4, 2008 | 08:13 PM
JamesC's Avatar
Or buy pre-bent lines from one of the following:
http://www.finelinesinc.com/
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Old Feb 4, 2008 | 08:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it's just the lines on the axle itself, I wouldn't bother with pre-bent. If it's the body lines, I wouldn't bother bending them myself.
Old Feb 4, 2008 | 08:26 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
Thanks for the time and info guys. I am going to order the Earls kit and bend my own lines on the axel.
Thanks again!
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
LittleFranks
Sep 17, 2015 12:22 PM
red90IROCls1
Aug 25, 2015 06:56 AM
