drilled slotted rotors quick question
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
can someone once and for all tell me if drilled slotted rotors have a specific side of the car to be installed on
because if you swap one way or another the holes are lined up or facing a different direction
also does it even matter performance wise in stopping???
thanks
thanks
Axle/Gears: no idea
Re: drilled slotted rotors quick question
wow thats great now which way is it
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i always get it confused so here is a pic, this is my passengerside
Axle/Gears: no idea
perfect thank you. if it mattered so much i dont know why they dont label them L and R.
but its fine thanks for setting it straight.
Car: 86 Trans Am
all the ones ive installed were marked left and right. on the car and on the truck. The marking are just stickers.
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Some companies like Baer have the rotation opposite,so check when installing them.
Axle/Gears: no idea
its weird the ones i buy off ebay for my camaro and trans am never were labeled. you figure a freakin L and R carved on the inside wouldnt be too darn hard
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
