need help wth break lights
Old Mar 26, 2008 | 06:17 PM
jugheads88gta's Avatar
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
ok so i cant get the break lights to come on in my 88 gta i put a new break light switch in that didnt work and the only wire coming from the break light is a yellow wire and there is no yellow wires coming from the break light switch ??i dont know what else to do plzz help
Old Mar 26, 2008 | 07:11 PM
Re: need help wth break lights
Checked the fuse?
The brake light switch has 2 wires; white and orange.
One of them has battery on it (orange I think); the other gets battery when you push the brake pedal.
That 12V goes up into the steering column, and gets manipulated by the turn signal switch, and sent to the individual bulbs according to whether that turn signal or the hazard flasher is active.
Meanwhile, the 3rd brake light is driven DIRECTLY off of the switch "ouput", before the TSS. Does it work?
Old Mar 26, 2008 | 07:52 PM
kcb37's Avatar
Have you checked to see if the light blub sockets are getting power?
If so and they do check the bulbs, if they are good you have a bad ground.
If you have no power to your brake lights, check your fuses first. If they are good, check the wires on the brake light switch as was already said one should be hot all the time.
Make sure that wire is getting power. Then check to see that you have continuity thru the brake switch with the brakes applied. If not the switch is bad. (yes new parts can be bad) If you have power to the switch and continuity thru the switch, then you have a bad connection at the switch or a bad wire.
Old Dec 7, 2008 | 07:30 PM
Car: 89 camaro
i figured it out all the wireing on my steering went bad so i had to just get a whole new one and now they work.
jaridjohn
Jul 8, 2024 03:49 PM
ktthecarguy
Jul 5, 2020 11:46 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
89fast5oh
Aug 24, 2015 08:14 AM
Omega
Aug 10, 2015 12:46 PM
