83 Z-28 parking brake problem
Old Apr 17, 2008 | 04:50 PM
gameguy45's Avatar
Ok so i have 83 camaro Z-28 with rear drum brakes. The parking brake doesnt hold at all. I've tried tightening the bracket underneath the car. Anyone have any suggestions?
Old Apr 18, 2008 | 05:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 83 Z-28 parking brake problem
Welcome to TGO. If you're running 20+ year old cables, their condition may be less than desirable. I'd start by checking them.
JamesC
Old Apr 18, 2008 | 07:23 AM
gameguy45's Avatar
They were replaced a few years ago. I believe in 05.
Old Apr 18, 2008 | 07:33 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
You need to start and first make sure the rear brakes are adjusted properly inside the drum. Once you know they are adjusted properly. Then set the cable tension. If the parking brake does still not work make sure all of the cables are ok. If there is still an issue. Make sure all of the e-brake cable tensioner's are in place. If everything else is working the e-brake should work fine.
1992rs/ss
Jan 31, 2025 05:10 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
