Anyone have pics of an adjustable prop valve installed?
Old May 19, 2008 | 09:16 PM
Firebat's Avatar
I've been trying to search for pics but come up with nothing. Its just easier for me to understand how to install one if I can see a pic of it. Where to get additional parts needed would also be useful info.
Old May 19, 2008 | 09:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Anyone have pics of an adjustable prop valve installed?
It's quite simple really..
the other thing is my line lock, You would just run your single brake line from the master cylinder into a TEE for the two front brake lines.
Attached Thumbnails Anyone have pics of an adjustable prop valve installed?-brake.jpg
Old May 20, 2008 | 06:12 PM
Firebat's Avatar
So, you get rid of the stock prop valve and just use a tee? Do some people keep the stock one and also use the adj prop valve?
Is your line lock going to a tee or does it tee off by itself? Little difficult to tell in the pics.
Old May 20, 2008 | 07:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
You can go either way, i would ditch the stocker alltogether.
i have a tee fitting screwed into my linelock that the two stock lines screw into..
Old May 21, 2008 | 04:50 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Wilwood prop valve with 94 master cylinder. Don't run the stock unit, whats the point other than the low brake fluid indicator.
Old May 21, 2008 | 07:03 PM
Firebat's Avatar
Can I get a tee from anywhere, like a hardware store? And probably can get brake lines from an auto store?
Old May 21, 2008 | 07:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
the auto store will also sell tee's
Old Jun 8, 2008 | 07:23 AM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
Can some one tell me what size thread are on our front and rear brakelines like on a '89 RS? I am looking for the right size T fitting to also hook up my willwood PPV as well
Old Jun 8, 2008 | 11:20 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
fronts should be 3/16" standard and the rear line is 1/4" standard. NOT METRIC.
Old Jun 8, 2008 | 03:19 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
my mistake I also forgot to ask what are the thread sizes as well on both? for a '89
Old Jun 8, 2008 | 08:27 PM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
here is mine installed next to the fuel filter. the stock rear drum combination valve stays in place under the hood, but the plunger and spring are removed from inside the valve.
Attached Thumbnails Anyone have pics of an adjustable prop valve installed?-apr2.jpg
Old Jun 8, 2008 | 10:13 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
if you go to a hardware store, ask for a 3/16 or 1/4 line, standard, you will get the proper thread.
Old Jun 9, 2008 | 08:12 AM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
wow thanks. And sorry for the threadjack Firebat
Old Jun 9, 2008 | 04:56 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Why under the car like that and not in the engine bay?
Old Jul 14, 2008 | 10:58 AM
Firebat's Avatar
Maybe you guys could help me on this thread: https://www.thirdgen.org/forums/brak...e-flaring.html
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
