ls1 master cylinder on a 3rd gen..
Old Jun 19, 2008 | 04:05 PM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
i remember talking to someone and they told me the treads or something was different, but then i saw one on a third gen. Is it a straight swap or?
Douglas
Old Jun 19, 2008 | 07:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ls1 master cylinder on a 3rd gen..
i have one on my car, and as far as i remember the threads were the same. The lines needed to be modified or rebent because they do not line up. You also need the pushrod that goes in the booster and pushes the masters piston.
Old Jun 19, 2008 | 07:53 PM
Firebat's Avatar
Its the LT1 booster that has different threads. The LS1 m.c. as said above, is the same size threads.
Old Jun 19, 2008 | 11:50 PM
Stephen's Avatar
Car: 87 GTA
What are the benefits of putting a LT or LS master cylinder in?
Old Jun 20, 2008 | 01:01 AM
Firebat's Avatar
Appearance wise - Looks nicer/cleaner and its smaller. I like the twist-on cap better than the thirdgen cap, just seems like you'd get a good seal everytime, thirdgen cap you got to watch it a little bit.
Performance wise - no gains.
Old Jun 20, 2008 | 06:30 AM
Engine: 350 v8
well i got it when i order my brakes out of cleveland, so i might as well put it on, a yes, i want to do it cause it will look at bit better, i hate the look of the stock one.....
Old Jun 20, 2008 | 04:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i dont believe that is true, the piston is smaller, which should provide a quicker, more positive action that the stocker with the huge piston
Old Jun 21, 2008 | 02:28 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
The pushrod from the LS1 mc??
Old Jun 22, 2008 | 08:45 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
Old Jun 22, 2008 | 09:01 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I found that out the hard way. Evidently, the LS1 pushrod (in my case 2002 Camaro SS, maybe the same?) is a bit shorter than the 3rd gen pushrod. Fortunately, the drive wasn't very far, but the longer 3rd gen pushrod put just enough pressure on the 4th gen M/C piston that my brakes were slightly engaged. They engaged enough to slow the car to a stop while in neutral going down hill. The brakes were very hot and I had some smoke from all four wheels.
Needless to say, until I find the correct pushrod, the stock master cylinder went back on.
Old Jun 23, 2008 | 03:16 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Never heard of this before.. I have an 02 master on my 82 booster with no trouble at all.. ls1 brakes front, pbr single piston in the rear..
Old Jun 23, 2008 | 03:47 PM
Stephen's Avatar
Car: 87 GTA
Am I understanding right? You used the 3rd gen pushrod on a 4th genMC & it didn't work out good? So, until you get a 4th gen pushrod, the swap is being put off?
Old Jun 23, 2008 | 04:26 PM
Al Hasse's Avatar
I think I also have an issue with that master cylinder. Until I figure out where the problem is, the stock M/C goes back on.
When I removed the 4th gen M/C, I exercised the piston and fluid would only come out where the rear brake line connects, nothing on the front. Seemed to work OK with booster pressure behind it while bleeding the brakes.
Old Jun 23, 2008 | 06:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yea, its a totally different design too, the 3rd gen one is just a rod, the 4th gen one has a larger flat end that fits better on the new piston.
I bought my ls1 master with the booster still attached so i had all the pieces, its the only way i would have noticed
Old Jun 24, 2008 | 01:31 AM
Car: 1991 Camaro
so is a ls1 booster needed, or can you just use the push rod from the donor car and it will work fine with the stock booster.
Old Jun 24, 2008 | 04:03 PM
Car: 1992 camaro
Axle/Gears: 3:73
No you dont need the booster.
Old Jun 24, 2008 | 07:48 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Ok, so a bit confused on this one.. like I mentioned above I went with the ls1 master and have my 82 booster, but no troubles at all..
This is the first I have heard about pushrod lengths being different and I know others on the board have done this without changing the pushrod or booster soooo, should I/we be concerned?
Old Jun 26, 2008 | 02:01 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Well answered my own question, took it up a nice hill, put it in neutral and went back down, no dragging of the brakes here.. Not sure why this is a problem for the person above and not for me.. I do have a fourth gen brake pedal however.
Old Jun 27, 2008 | 09:58 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
I too have a third gen pushrod and LS1 Master with no problems. I just got back from a 1800 mile trip in it and no issues for me. If this is a concern though I may look into changing it. I have no dragging issues and the car still gets the same gas mileage as before the swap, which if they were hanging up I would think it would be lower.
Old Jun 27, 2008 | 09:03 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
I don't think this is a common problem, my car stops on a dime.. I was worried since my switch over is recent, but on the hill it went 80mph just coasting and would of gone faster if I'd of let it.. Something to watch out for, but not to sweat about is my thoughts on this..
Old Jun 27, 2008 | 09:19 PM
Al Hasse's Avatar
From reading all the responses, Id have to agree. I'm thinking the problem I had with mine was with the master cylinder itself (chances you take with used equipment) and had noting to do with the booster's pushrod. When I finish with other brake projects, I'll have to take a good look at this thing or get a new one to complete the swap.
Old Jun 28, 2008 | 12:21 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Keep us posted, info is good to have..
I just noticed you were a bubblehead.. I was a skimmer or target for you folks..
Old Jul 10, 2008 | 11:10 AM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Does it have to be an LS1 master cylinder? Or will one work out of a V6 4th gen?
Old Jul 10, 2008 | 12:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it needs to be from a 98-02 car, motor doesnt matter
Old Jul 14, 2008 | 05:23 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I (well my stepday) installed a LS1 MC/1LE prop valve/ SLP linelock yesterday, while I was under the car buttoning up the 4th gen rear swap. The MC just installed right in place of the 3rd gen unit, no changing of the rod. Just removed the 3rd gen MC and installed the LS1 MC.
Old Jul 15, 2008 | 03:23 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Same for me, direct bolt on, had to bend some lines a little but that was it. I'm not sure why others are having issues, if all of the brake lines have the same threads.
Old Jul 22, 2008 | 01:51 PM
Al Hasse's Avatar
I retired in Oct '99, now I work in avionics doing kind of the same thing as before.
I might be trying this again next weekend. I took apart the master cylinder I acquired and cleaned it up pretty good - there was alot of gunk inside. I compared booster pushrods while at the junkyard today and noticed there is a significant difference in length most likely due to the depth difference between the two boosters.
Is it possible that the piston in my master cylinder was hanging in the bore due to the junk inside? Maybe this could have caused the excess pressure I had in the system???
db057
Apr 28, 2019 07:45 AM
dbrochard
Sep 19, 2015 08:13 PM
ericjon262
Sep 11, 2015 06:07 PM
timonator
Sep 10, 2015 07:55 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
