Having leaks, need to fix asap, please help
Old Aug 14, 2008 | 07:06 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
I got the Earls hyperfirm kit and where the brake lines go into the T fitting for the real brakes is leaking a lot [20$ flaring kit, does not work!]
So im going to order some of this-
http://www.jegs.com/p/Earl%27s/749428/10002/-1/10143
I need to know what fittings I need for the ends of the new brake lines so I can order this and get my car drivable. I couldent find anywhere what size the stock brake fittings are.
Old Aug 14, 2008 | 08:19 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: Having leaks, need to fix asap, please help
I just did this fix, i put in my new rear end and it was leaking at the t valve, had to cut the lines about 5 inches away and bent and flare new lines and tighten them down real tight, thats why they leak, you gotta keep going tighter and tighter without stripping them, a flare nut wrench is your friend with brake lines. as for the sizes of fittings, at pep boys i went and bought the 3/16 fittings. Are those what your referring to? The factory brake lines were 3/16.
Old Aug 14, 2008 | 09:01 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
The flare kit I have does a terrible job and I dont feel like going out and buying a nicer one.
Im referring to the actual nut? the actual thing that screws into the T fittting.
I already ordered the line, so I guess I need to search for a -03 to 3/16th adapter?
Old Aug 14, 2008 | 09:25 PM
Saber's Avatar
Well the brake lines are 3/16, and if your flare kit is bad, try renting one from autozone you get your money back, its the one i used and it worked great. But Braided lines are the way to go so if your got the money go for it. Your just trying to figure out what size fitting goes into the t valve correct?
Old Aug 14, 2008 | 09:34 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Correct, I already ordered the line, so I just need 4 adapter fittings -03 to whatever size the factory stuff is.
Old Aug 14, 2008 | 10:05 PM
Saber's Avatar
Factory stuff is 3/16 thats what i used so you should have no problems with it.
Old Aug 14, 2008 | 10:13 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Guess ill order these-
http://www.jegs.com/i/Russell/799/660551/10002/-1
Old Aug 15, 2008 | 02:50 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
I called Jegs and canceled the Earls line.
The adapters I need is too complex to figure out and expensive.
I think im just going to get line from www.finelinesinc.com, but I have no idea what part number I need and they dont have pictures so I cant tell if they come with everything I need.
Old Aug 17, 2008 | 08:42 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Your car will have all metric fittings, no standard sizes. I take it you are doing rear discs but what style are they, the older ones or the '89-92 rear discs?
These are the part numbers you need:
Early style iron calipers: FRA8602OM
late style PBR aluminum rear discs (including '93-97 rear discs): FRA8901OM
This will get you fixed up.
Ed
Old Aug 17, 2008 | 08:47 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Im doing a full LS1 rear end with LS1 brakes, from a 2001.
I ordered -
FRA8401SS
FRA8901OM
Those two, they have like no description or pictures on their site, so I picked 2 that seemed like maybe what I needed.
Old Aug 17, 2008 | 08:59 AM
ebmiller88's Avatar
Even with the LS1 discs the calipers and lines will bolt up the same. They 8901OM lines are correct for you, enjoy the hassle free install. I use Fine Lines all the time.
Ed
Old Aug 17, 2008 | 09:03 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Any idea what the other thing I ordered is? lol
Im glad I ordered the right thing then. Ill just bolt em on real tight, and hopefully shouldent have any more leaks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Fronzizzle
Sep 8, 2015 12:10 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
rjcme
Sep 5, 2015 01:23 PM
tgp1990
Sep 4, 2015 06:24 AM
