stock 10 bolt disc brakes. will they fit racelites?
Old Sep 14, 2008 | 04:50 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Hey guys I am in a huge bind. I have a ls1 diff with original ls1 brakes. They are way to big to fit the 15x10 racelites I have. I changed out the brakes to lt1 brakes and they still are too big. I grinded the **** out of the mand it still rubs.
What i want to know is how big are the stock 10 bolt disc brakes?
Has anyone else fit the racelites with them on and/or is there a company that makes custom brakes
Old Sep 14, 2008 | 06:46 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: stock 10 bolt disc brakes. will they fit racelites?
The PBR brakes from 89 and up are 11.65", Ls1 brakes are 12" and i believe the pre 89 iron caliper brakes are something like 9.5 or 10 inches.
Old Sep 14, 2008 | 07:07 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
do you know if the lt1 backing plate will hold the 88 and older caliper?
Old Sep 14, 2008 | 09:08 PM
Saber's Avatar
I believe they are different. How bad is the grinding?
Old Sep 14, 2008 | 10:51 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i did almost an inch of grinding. It was rediculous. I recommend to not have thse rims unless you have a older disc brake setup or drum brake.
Old Sep 15, 2008 | 06:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
10.5. The backing plates, 82-88 and 89-97, are very different. You can see the two in the following link (post 1 and 20):
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Sep 15, 2008 | 11:08 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
also are the backing plates the same for both sides?
Old Sep 15, 2008 | 11:47 AM
Saber's Avatar
Yes on the older brakes, the calipers are actually on reverse sides so they can use the same backing plate. I would sell you the whole brake setup, but i have it for a 9 bolt, and im not too sure if there is any difference on the backing plates.
Old Sep 15, 2008 | 12:40 PM
JamesC's Avatar
Bolt-hole alignment is different.
JamesC
Old Sep 15, 2008 | 02:12 PM
Saber's Avatar
JamesC
On a 9 bolt vs a 10 bolt?
What about a ls1 rear like he has, vs the stock 10 bolt the iron calipers came on?
Old Sep 15, 2008 | 02:16 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
well I went to advance and they sell the backing plate but it's the Sam p/nfor a 88. I know they are diff for the ls1 but not for a thirdgen?
Old Sep 15, 2008 | 02:40 PM
Saber's Avatar
The backing plates for the brakes in question should be the same every year they were used, so you could buy them for an 88, and they would fit an 87 etc, as long as the rear was equipped with those brakes originally. But you have a ls1 rear and im not sure if you would have to modify them to fit on your rear end.
Old Sep 15, 2008 | 02:41 PM
JamesC's Avatar
Yes.
The 10-bolt alignment, 89-97, would be the same certainly. I "assume" it's the same for the LS1 10-bolt; however, I have no personal experience with LS1.
JamesC
Old Sep 16, 2008 | 09:15 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
well to be honest lt1 brakes do not fit perfect on a ten bolt ls1. the axles are like .2 of a inch too long so you need shims.
Im guessing I will have to do the same for these
Old Sep 16, 2008 | 08:49 PM
Saber's Avatar
Have you looked into any aftermarket rear brakes?
Old Sep 16, 2008 | 10:05 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
that's my next stop
Has anyone put drum brakes on the back of an ls1 rear
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
