disk brake rear end E brake
Old Oct 27, 2008 | 02:58 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
The ebrake on the formula works but not all that well. What has to be done to adjust this? I think it just needs to be tightened up a little
Old Oct 27, 2008 | 03:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: disk brake rear end E brake
Adjustment is made near the middle of the car above the drive shaft. If that doesn't work (and I assume you have PBR's), check "free travel."
https://www.thirdgen.org/forums/susp...ee+%252Btravel
JamesC
Old Oct 27, 2008 | 05:25 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
PBRs?
Old Oct 27, 2008 | 06:00 PM
JamesC's Avatar
PBRs?
11.7" rotors and single-piston alum calipers.
JamesC
Old Oct 27, 2008 | 06:13 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
oh ok, if thats the stock disk brakes then thats what i have
car does have an aluminum drive shaft and WS6 suspension, would be nice if i had the 1LE brakes lol
Old Oct 27, 2008 | 06:36 PM
JamesC's Avatar
Easy enough to do:
http://web.archive.org/web/200605221.../1LEbrake.html
Spohn and Ed Miller both may sell kits.
JamesC
Old Oct 27, 2008 | 06:52 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
that doesn't seem like it would be to hard of a swap, better brakes are always a plus. especially the way i drive
EDIT: damn the 1le kit from sphon is $850 I think the LS1 brake kit from bigbrakeupgrade.com for $669 would be a better option now
Old Oct 27, 2008 | 07:01 PM
JamesC's Avatar
I did the 1LE conversion, front and rear, before the bigger kits started appearing--I also wanted the calipers to match (yes, I'm ****). You may, however, find what your looking for on Ed's web site:
http://www.flynbye.com/
JamesC
Old Oct 27, 2008 | 07:11 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
that site has a lot of good options for brake upgrades, thanks
that C6 Z06 kit looks nice, would give me a reason to get the 18" C6 wheels i have been looking at since i got the car
hectre13
Dec 11, 2023 08:14 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
novaderrik
Aug 10, 2015 12:44 PM
