Russell or Earl's Which lines are better?
Old Nov 29, 2008 | 12:19 AM
thirdgenfcarnut's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
Last year I replaced all the worn parts of my brakes, (calipers, pads, rotors, bearings, rubber lines, drums, shoes, spring kit, and cylinders). I have decided to begin upgrading my brake system. The first thing I want to do is ditch the rubber brake lines and go with hyperfirm lines. Which product is better as far as quality of construction, reliability, and ease of installation? Russell or Earl's? The only other upgrade I plan on is the 1LE front brake swap, but that will not be for another year.
Old Nov 29, 2008 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Russell or Earl's Which lines are better?
After reading many posts on the subject, I'd say Earl's gets the nod.
JamesC
Old Nov 29, 2008 | 09:28 AM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
As I search this board, I noticed that just about every member talks about the Earls in their posts. The Russell lines are more expensive by a couple bucks... How is the fitment of the Earls? Bolt right in? Everything line up nicely? If I get these... EAR-28A180ERL... the front disc/rear drum set, will the front lines work with a 1LE front front brake upgrade? I have read so many posts here and cannot find a specific answer to this
Old Nov 29, 2008 | 10:26 AM
JamesC's Avatar
Fine. Yes. Yes. No (the 1LE version is longer).
JamesC
Old Nov 29, 2008 | 12:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
earls hands down
i dont like russells parts to begin with (edelbrock), they have good manifolds and water pumps, thats about it.
There is at least one thread on this board about russell lines blowing out and causing an accident
IIRC im using the standard front flex lines, not the 1le ones, with c5 calipers and have no problems with length
Old Nov 29, 2008 | 02:53 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
IIRC there is a member on here mabey he will chime in and show you one GOOD reason to go with earl's.
Old Nov 29, 2008 | 03:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
https://www.thirdgen.org/forums/brak...ghlight=russel
check out post #9 from quadgoat, see what happened
Old Nov 29, 2008 | 05:09 PM
Car: 1992 camaro
Axle/Gears: 3:73
Thats the one.
Old Nov 30, 2008 | 08:34 AM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
WOW That is some scary stuff. Rubber lines are starting to look good...
Old Nov 30, 2008 | 10:32 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
That Earls line that failed in the thread is mine, the one that burst and caused the crash was a russel line. I am still running Earl's though. New set they sent me works just fine They told me all their testing procedures before they leave and it IS pretty extensive, enough for me to try them again..
Just make sure you do a nice hard test with lots of runout.
Old Nov 30, 2008 | 12:14 PM
bluethunder28's Avatar
I use Goodridge lines after a factory line failed while autoxing
Old Dec 4, 2008 | 07:45 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I had an Earl's line fail while backing out of the driveway in my Monte. The line ruptured right where the braid enters the metal end connector.
I replaced my lines with Russell's, and IMO the Russell lines just look and feel like better quality parts. The Russell lines also have a poly coating over the steel braid and an extra poly sheath over that where it enters the metal end connectors (2 poly sheaths where it enters the connector).
Hotrodboba400
Dec 10, 2019 07:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
