LS1 brakes on a lowered car
Old Dec 6, 2008 | 04:45 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I talked to Ed Miller the other day regarding an LS1/C5 brake upgrade and he mentioned that the conversion will increase the track on the car by .300 of inch on each side. I am going to do a drop on my car by about 1.5 inchs and was wondering if anyone has had any clearance problems with the change in specs on width on a lowered car with the LS1 or C5 brake kits. I am running a 17X8 IROC with 255/40/17 tires.
Also, is the .300 change noticable in appearance? Does it look funny at all?
Old Dec 6, 2008 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 brakes on a lowered car
what backspacing are you wheels?
im using the c5 brakes, with 18x8's with 4.5" of bs and have no issues whatsoever.
.300 is a third of an inch, you probably wont even notice it.
Old Dec 6, 2008 | 06:25 PM
burnout88's Avatar
Car: 88 IROC
Offset is 0mm,
4.50" backspacing, it sounds like you have the same backspacing as my wheels, are you lowered at all?
Old Dec 6, 2008 | 08:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by burnout88
Offset is 0mm,
yea, about the height of a prokit, about 1-1.5" lowered, ive been lower. No issues
Old Dec 6, 2008 | 11:09 PM
burnout88's Avatar
Car: 88 IROC
Ok cool, I think will go ahead and do the C5 upgrade now that I have some confindence that I will not have a problem once I lower the car. A lowered just looks so good
Thanks again,
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
