Pic Of Drum Brakes
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Pic Of Drum Brakes
i need a pic of the drum brakes and how they are set up, i got an axle that has now hardware on it that i need to put brakes on, and my old axle has everything off of it to
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Pic Of Drum Brakes
This is mine as I finished up rebuilding them after buying the car. The picture is the driver side and as you can see, the longer shoe goes to the rear.
Since you already have a good pic, a thought for you.
If it's been a while since you last drained and refilled the diff, wouldn't hurt to do the axle seals, if not bearings too. While your in the area.
That's what my passenger side rear looked like when I bought it.
Parts stores told me they couldn't get the seals, dealer wanted like $15 a piece, got them from summit for $3 something a piece.
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
please tell me how you removed your wheel cylinder retainer clip. i cant get that thing off!!
For my rebuild, I didn't remove the wheel cylinders, they weren't leaking at the time and still weren't when I replaced the whole rear end for disc. I rebuilt these because the previous owner decided to replace the shoes after putting some nice grooves in the driver side drum, since I was replacing drums and shoes, the rebuild kit (mostly springs and clips) wasn't a whole lot more.
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
I took my drum off the drivers side to look at the ebrake assembly. I haven't figured out whats wrong yet, but I haven't taken it apart yet either. I was a little occupied with the transmission today.
so heres my pic.
so heres my pic.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
AkDrifted
Aug 17, 2015 07:45 PM
