Need help picking out rear disk brake kit for 9 inch.
Old Apr 5, 2009 | 03:57 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
I need some help. I'm building a prostreet camaro, and I would like to keep an e-brake. I would really like to buy the Wilwood kit with the internal drum e-brake, but to install it your axles need an access hole in the axle flange. My Moser axles don't have a hole. That kit is a little pricey anyway.
Do I need a kit with drilled and slotted rotors?
This kit from Jeg's looks nice. http://www.jegs.com/p/Right+Stuff/1164460/10002/-1 Will this kit work with new style big bearing housing ends?
Old Apr 7, 2009 | 10:35 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Need help picking out rear disk brake kit for 9 inch.
I have at least one rear kit for new Ford style with PBR style calipers and correct backing plates. I'll let you know what I have in the shop, it'll fit that application.
Ed
Old Apr 7, 2009 | 03:37 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Sounds interesting. Sorry for my ignorance, what is PBR style caliper? What rotors will I need? Will it all fit inside a 15" rim?
Old Apr 7, 2009 | 04:25 PM
rlandrum's Avatar
Car: 1986 IROC-Z
My Moser axles came with a hole. Even so, it wasn't large enough for any socket and I ended up turning down a spark plug socket to get them on. Moser also sent me the Wilwoods and they installed easily enough. I haven't used them yet though. Still a work in progress.
I would imagine that you could drill the axle flanges, or have a machine shop do it for you for a nominal fee.
Old Apr 7, 2009 | 04:37 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
That would be an option. I wonder if the axle flange is hardened.
Old Apr 7, 2009 | 07:04 PM
ebmiller88's Avatar
I do have the Ford backing plates in the shop.. and they're the new style so they will work foryou. We can build you a rear 1LE style kit with 11.6" rotors to fit your 16" wheels. How soon do you need the brakes installed? LMK.
Ed
Old Apr 7, 2009 | 08:36 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Ed
I'm not in a huge hurry to buy. I'll need a brake kit soon though. Maybe in a week or two.
I hope you meant to say 15" wheels.
What is the difference between 1LE and PBR calipers?
Old Apr 8, 2009 | 08:41 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I have a moser 9 in. with LS1 style rear brakes. I bought the brakes from Ed (thanks ed, they work awesome!) and the backing plates from the shop I bought the rear from. They fit my 16" Iroc wheels. I forget which part numbers I used for parking brake cables, but I can dig it up if you need it. I only needed to open up the end that goes on the bracket near the wheel and add a few spacers up by the tensioner. Works for me.
Old Apr 8, 2009 | 12:03 PM
ebmiller88's Avatar
Oops, sorry about the typo. I did mean 15" wheels but the plates I have are for a 12" rotor but I can have the brackets done for the slightly smaller 11.6" rotors in about a week, I'll have both on hand.
PBR makes the 1LE calipers as well as most GM aluminum calipers: LS1, Corvette, trucks, etc, therefore PBR calipers will be stock 1LE/LT1 calipers from '89-97.
Ed
Old Apr 8, 2009 | 03:21 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
What's the price on the kit. What will I need to buy?
Old Apr 16, 2009 | 06:22 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Have you made any progress Ed?
Old Apr 23, 2009 | 06:29 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Are the brackets done Ed?
Old Apr 23, 2009 | 07:40 PM
ebmiller88's Avatar
Yes, pattern is done but I haven't had them cut yet. I can send it off tomorrow and I'll have them in about a week or so. How's that?
Ed
Old Apr 24, 2009 | 04:07 AM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
That sounds good. I can wait some more.
Old May 6, 2009 | 02:34 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
Sorry to thread jack but, ed can you PM me a price on a kit just like this?
Old May 6, 2009 | 03:40 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I would like a price too.
Old May 9, 2009 | 05:37 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Any progress on the brackets Ed? I need brakes soon.
Old May 16, 2009 | 12:11 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I could not wait anymore. I ordered a brake kit from Jeg's. Thanks anyway Ed.
Old May 17, 2009 | 08:50 PM
ebmiller88's Avatar
I understand, I just got off vacation and the parts should be ready to pick up tomorrow from the plater. Good luck with your brakes!
Ed
Old May 21, 2009 | 12:07 PM
ebmiller88's Avatar
Picked them up today, we're good to go on Moser and Strange with big Ford ends, small Ford (8.8") to come soon as well. One thing to note, you need to know your offset/overhang from axle flange to axle housing flange. GM is usually 2.75-2.8" and Ford can be 2.36" so keep that in mind, it will change the rotor selection.
Ed
Old May 21, 2009 | 04:35 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
I wish I could have waited. Oh well.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
red90IROCls1
Aug 25, 2015 06:56 AM
