9 bolt hardline 2 caliper
Old Apr 24, 2009 | 04:38 PM
jabz28's Avatar
Car: 84 z28
Engine: 400 sb RIP down to a 350
Transmission: turbo 400
Axle/Gears: posi 373
I just had my 9 bolt rebuilt, and just got it in the and began to hook up all the brakes to get them ready 2 be bled. I replaced my drivers side hard line to caliper because the fitting was stripped and now it leaks and i can kinda of push the line in and out, i completely tightened it so its not loose and the fitting is correct and not leaking at the t, does anyone know why this is happening and if i can just change it to rubber line.
Old Apr 25, 2009 | 12:57 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 9 bolt hardline 2 caliper
You used new crush washers on the banjo bolt, right?
Ed
Old Apr 25, 2009 | 12:56 PM
jabz28's Avatar
Car: 84 z28
with this rear brake setup the passanger side has that but the driver witch is leaking is a hardline
Old Apr 25, 2009 | 10:19 PM
bigals87z28's Avatar
Car: Check The Sig
You know, I put my calipers on, and noticed that there were no crush washers for teh calipers? That is odd....
Not to hijack this thread, but does anyone know if the LT1 rear brakes can be a direct replacement for the PBR's on the third gens?
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
