91 GTA: problems with e-brake cables
Old May 26, 2009 | 11:47 AM
gta88 flamered's Avatar
Car: GTA 89
Transmission: TH700
Hi guys,
I’m replacing the e-brake cables of a 91 GTA with rear disc brakes with the the 1st design cables, length 1434 mm.
There is a problem: the cables seem to be too short. Even with the caliper levers pushed away from the discs there is only 25mm free cable length between the guidance on the underbody and the cable ends.
If I try to connect the cables to the equalizer, one of the cables is always slipping out of the guidance on the underbody (see picture attached).
Does anybody have an idea what the problem can be?
Jens
Old May 26, 2009 | 12:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 91 GTA: problems with e-brake cables
You need the second design. Check the following link, post #4:
https://www.thirdgen.org/forums/brak...r-e-brake.html
JamesC
Old May 26, 2009 | 01:29 PM
Car: GTA 89
Transmission: TH700
Thank you for your very fast feedback.
What I've used are the Raybestos BC94264. What Raybestos Part-No do I need? (The best chance to get the right parts here in Germany is the correct manufacturer's part no)...
Old May 26, 2009 | 03:47 PM
JamesC's Avatar
I checked the following site for a 1991 Pontiac 5.7 GTA and found several 1460 mm lines that will work, to include Raybestos BC94597--please double check for yourself:
http://www.rockauto.com/
JamesC
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
