[STICKY THIS] Brake Cleaner can kill
Old Jul 24, 2009 | 02:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
[STICKY THIS] Brake Cleaner can kill if exposed to heat and argon gas and there is no antidote.
http://www.brewracingframes.com/id75.htm
Old Jul 24, 2009 | 10:14 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: [STICKY THIS] Brake Cleaner can kill
Oh my. Yea lots of stuff out there can kill a guy
Old Jul 25, 2009 | 01:27 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Of course but if you read it, it only take a tiny small puff of the smoke and your done. That dude went through enough as is.
And how many of us have just hosed down parts with whole giant cans of that stuff that would be enough to kill a whole town.
Old Jul 25, 2009 | 06:56 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I knew brake cleaner was some nasty stuff, but WOW!
Old Jul 25, 2009 | 08:06 PM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
I just read about this story on yellow bullet, that dude is lucky to be alive.
Old Jul 27, 2009 | 08:09 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Not all brake clean contains the nasty chemical that caused this guy's problems. I checked the stuff I use at work today and it didn't have it. But it wouldn't surprise me if there are some carb/choke cleaners out there that have this stuff in them too.
Usually anything I spray down with brake clean gets a good blast of compressed air afterward.
Old Jul 27, 2009 | 08:25 PM
Guest
Guest
Posts: n/a
Are you kidding me? You want a sticky warning about some moron spraying chemicals onto a surface just before he lights it on fire with a torch?
How many idiots do we want to save in this world?
Hey TGO, Chemicals and fire are bad- please sticky this becasue people are dumb.
Wire brushes people, wire brushes (And not stainless ones either- I thought this was 2nd grade knowledge)
Old Jul 27, 2009 | 08:31 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
if its hydrogen chloride it takes 50 parts per million to kill
Old Jul 27, 2009 | 08:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
many things can kill, especially when mixed. The common bleach and ammonia makes chlorine gas or something similar which will kill you as well. Burning chemicals, mixing chemicals, drinking chemicals is always a bad idea, it should be common knowledge, but you can protect all the people in this world from their own stupidity or lapses in judgment.
Old Jul 27, 2009 | 08:58 PM
laiky's Avatar
In this case, should you degrease something with chlorinated brake cleaner then lean in to TIG or MIG it you can quickly poison yourself severely and irreversably. Most experienced welders don't use brake cleaner since it leaves residue, but if you don't know and grab the stuff everyone uses for degreasing parts and they are not completely dry you can die or be crippled withput any fire or explosion. This reaction requires chlorinated chemicals and Argon gas.
Old Jul 27, 2009 | 09:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
my question is, while im not a professional welder, i have a good amount of welding experience, i dont understand why you would spray anything onto a surface your going to weld? Residue will cause contamination of the weld and porosity.
Old Jul 27, 2009 | 09:14 PM
89RS_82Z's Avatar
wait its makes Phosgene gas thats the worse of the worse take 2 parts per million to kill color less and has a musty hay oder and tasteless, it forms hydrochloric acid in your lungs
Old Jul 28, 2009 | 12:53 PM
laiky's Avatar
In this case he cleaned with Chlorinated brake cleaner, but the part wasn't completely dry. Either way you should avoid brake cleaner anyhow, it's unfriendly stuff. My self and most of my mechanic friends use it only when necessary now. The less you breath and touch the stuff the better off you are.
Old Aug 3, 2009 | 12:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally Posted by Vetruck
Are you kidding me?
When you have more then a 1000 post under your belt; then Ill value your opinion
Old Aug 3, 2009 | 04:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Old Aug 4, 2009 | 01:29 PM
Guest
Guest
Posts: n/a
Are you kidding me.........AGAIN?
Just because you have made '4900 idiotic statments' and pressed the 'send' button makes you 'creditable'?
Besides, research me and you'll know who I am and how many years I have been around here. I own a certain V6 car.
Dean
Old Aug 5, 2009 | 02:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I have over 8000 idiotic post if you include my first account that was banned; so there.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
