Broken brake hard line
Old Jul 25, 2009 | 04:17 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I have a 1991 Z28 with drum rears. The hard line that runs from the master all the way to the t-fitting on the rear axle broke right where it goes into the t-fitting. Is this line metric? I thought I would cut the line back,put a union in and bend a new line. Probably about 2 feet long. Can anyone tell me:
1:Size of brake line and fitting that goes into the tee
2:double flare or bubble flare?
Old Jul 25, 2009 | 07:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Broken brake hard line
i think its 6mm, its bubble flare.
Old Jul 26, 2009 | 05:58 PM
remltr's Avatar
Looks like the rear is 6mm with a 12mmx1 bubble flare. Does anyone know the size that comes of the proportioning valve? Is it 6mm tube with a 14mmx1.5 bubble flare? I think I will just replace the entire line.
Old Jul 26, 2009 | 06:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you can buy new lines, fittings and all. It will save you the hassle of buying a flaring tool, finding fittings, flaring the tubing, cussing ect.
check out finelines or classistube
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
