lt1 front brakes?
Old Nov 8, 2009 | 06:44 PM
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
lt1 front brakes?
I just put in a lt1 rear in my 88 firebird and was wondering if anyone knew if i could up grade the front brakes to lt1 brakes. Mind you i used this axle because i a running 03 corvette wheels and didnt really want to run spacers in the back
Old Nov 8, 2009 | 07:51 PM
RU1NER's Avatar
Re: lt1 front brakes?
Pretty sure lt1 brakes (from camaro and firebird) our the same as ours.
Old Nov 8, 2009 | 08:59 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
they arent the same, but arent any better.
if you spend the money go aftermarket or go with the ls1 stuff.
Old Nov 10, 2009 | 05:00 PM
howesbird's Avatar
Engine: Pontiac 400
Transmission: 4L80e
How would i do ls1 brake on my car
Old Nov 10, 2009 | 08:17 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
do a search in the brake forum. there are fair amounts of threads on this.
i believe ed makes a pretty much bolt on kit.
Old Nov 10, 2009 | 08:51 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
just ran across this thread.
https://www.thirdgen.org/forums/exte...ont-brake.html
Old Nov 10, 2009 | 09:10 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
If I was to put LT1 front brakes on I wouldnt have to run front spacers correct? And if so could I just change out the rotors and cal it good or is there a lot more to it?
Old Nov 10, 2009 | 09:40 PM
thegooseman's Avatar
Car: 1992 RS
www.bigbrakeupgrade.com
Its a bolt in kit for a good price. He even offers a corvette setup too.
Old Nov 10, 2009 | 09:56 PM
Axle/Gears: stock
$600??? WOW. Im thinking on finden a blown up 4th gen and stealin the rotors and rearend. I know I can use the rearend but what about the front?
Old Nov 10, 2009 | 10:04 PM
Car: 1992 RS
Using fourthgen front brakes you need to modify the spindles, grind down the hubs, ect, ect. I think that kit is a good deal.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
